Interrogator log error
I have tried 3 times to do the interrogator log to see if my replacement head is a 2020 or newer but each time it gives me an error that the file could not be read
Install Type: Replica
Old SYNC Version: 3.420282
New SYNC Version: 3.422251
The XML file you have selected could not be read, please ensure it is the correct file.
Syn3 Updater Version: 2.11.5.0
-<p:OTAModuleSnapShot xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd" version="2022-11-08" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0">
<p:VIN></p:VIN>
-<p:RequestRole>
</p:RequestRole>
-<p:BroadcastDTCType>
<d2p1:DTC DTCValue="91ba1c48"/>
<d2p1:DTC DTCValue="91ba6348"/>
<d2p1:DTC DTCValue="c1980048"/>
<d2p1:DTC DTCValue="c2930048"/>
</p:BroadcastDTCType>
-<p:Node specificationCategory="GGDS" isFlashed="false">
-<d2p1:ECUAcronym name="APIM">
-<d2p1:State>
-<d2p1:Gateway gatewayType="NONE">
-<d2p1:DID responseLength="24" didValue="8033" didType="Embedded Consumer Operating System Part Number" didFormat="ASCII">
<d2p1:Response>5U5T-14G381-EK</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength="384" didValue="8060" didType="Embedded Consumer Applications Part Numbers 1" didFormat="Packeted">
<d2p1:Response>345535542d3134473432312d434143000000000000000000345535542d3134473432312d434243000000000000000000345535542d3134473432312d434343000000000000000000345535542d3134473432312d434443000000000000000000345535542d3134473432312d434543000000000000000000345535542d3134473432312d434643000000000000000000345535542d3134473432312d434743000000000000000000345535542d3134473432312d434843000000000000000000345535542d3134473432312d434a43000000000000000000355535542d3134473339312d434c00000000000000000000345535542d3134473432322d434146000000000000000000345535542d3134473432322d434246000000000000000000345535542d3134473432322d434346000000000000000000345535542d3134473432332d434100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength="384" didValue="8061" didType="Embedded Consumer Applications Part Numbers 1" didFormat="Packeted">
</d2p1:DID>
-<d2p1:DID responseLength="4" didValue="D704" didType="ECU Checksum 1" didFormat="HEX">
<d2p1:Response>00000000</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength="4" didValue="D705" didType="ECU Checksum 2" didFormat="HEX">
</d2p1:DID>
-<d2p1:DID didValue="DE00" didType="Direct Configuraation DID DE00">
<d2p1:Response>aaae0103a6020b020480</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue="DE01" didType="Direct Configuraation DID DE01">
<d2p1:Response>55530103b002000000000000</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue="DE02" didType="Direct Configuraation DID DE02">
<d2p1:Response>0000010100</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue="DE03" didType="Direct Configuraation DID DE03">
<d2p1:Response>010014000e0002</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue="DE04" didType="Direct Configuraation DID DE04">
<d2p1:Response>1a681a6838a4</d2p1:Response>
</d2p1:DID>
-<d2p1:DID didValue="DE05" didType="Direct Configuraation DID DE05">
</d2p1:DID>
-<d2p1:DID didValue="DE06" didType="Direct Configuraation DID DE06">
<d2p1:Response>3f003300000000029a000056569200c8</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength="24" didValue="F110" didType="On-line Diagnostic Database Reference Number" didFormat="ASCII">
<d2p1:Response>DS-GB5T-14G371-AF</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength="24" didValue="F111" didType="ECU Core Assembly Number" didFormat="ASCII">
<d2p1:Response/>
</d2p1:DID>
-<d2p1:DID responseLength="24" didValue="F113" didType="ECU Delivery Assembly Number" didFormat="ASCII">
<d2p1:Response/>
</d2p1:DID>
-<d2p1:DID responseLength="24" didValue="F124" didType="ECU Calibration Data #1 Number" didFormat="ASCII">
<d2p1:Response>GB5T-14G375-BA</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength="16" didValue="F141" didType="Private Sub Node #1 Serial Number" didFormat="ASCII">
<d2p1:Response>WX2K43B3</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength="1" didValue="F162" didType="Software Download Specification Version" didFormat="State Encoded">
</d2p1:DID>
-<d2p1:DID responseLength="1" didValue="F163" didType="Diagnostic Specification Version" didFormat="State Encoded">
</d2p1:DID>
-<d2p1:DID responseLength="24" didValue="F188" didType="Vehicle Manufacturer ECU Software Number" didFormat="ASCII">
<d2p1:Response>GB5T-14G374-AF</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength="16" didValue="F18C" didType="ECU Serial Number" didFormat="ASCII">
<d2p1:Response/>
</d2p1:DID>
-<d2p1:DID responseLength="6" didValue="F1D0" didType="ECU MAC Address 1" didFormat="HEX">
<d2p1:Response>98:5d:ad:ba:2c:bc</d2p1:Response>
</d2p1:DID>
-<d2p1:DID responseLength="6" didValue="F1D1" didType="ECU MAC Address 2" didFormat="HEX">
<d2p1:Response>98:5d:ad:ba:2c:bd</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:ODLNetwork d2p1:Pins="6,14" d2p1:DLCName="SAE J1962" d2p1:NetworkProtocol="CAN" d2p1:NetworkName="HS-CAN" d2p1:NetworkDataRate="500"/>
-<d2p1:AdditionalAttributes vmcuVersion="Vector_VMCU_02.02.20" RAM="1022148608" logGeneratedDateTime="2022-11-08T13:27:37+00:00">
<d2p1:PartitionHealth available="12M" total="1.4G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="36K" total="1.4G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="148K" total="1.4G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="12M" total="1.3G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="3.0M" total="922M" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="9.3M" total="1.3G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="16M" total="1.7G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="13M" total="2.0G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="15M" total="1.6G" type="/fs/Nuance/"/>
<d2p1:PartitionHealth available="10M" total="1.1G" type="/fs/Nuance/"/>
<d2p1:PartitionHealth available="24M" total="2.6G" type="/fs/Nuance/"/>
<d2p1:PartitionHealth available="3.1M" total="465M" type="/fs/Nuance/"/>
<d2p1:PartitionHealth available="57M" total="1.0G" type="/fs/Nuance/grace"/>
<d2p1:PartitionHealth available="864M" total="1.2G" type="/fs/rwdata/"/>
<d2p1:PartitionHealth available="35M" total="35M" type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available="90M" total="90M" type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available="128M" total="1.4G" type="/fs/mp/"/>
<d2p1:PartitionHealth available="3.6G" total="25G" type="/fs/images/"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Your log file is incomplete therefore there is no way to know if it’s my20 or not.
You will need to check the model number on the APIM physically
You should fix your DTC’s before you upgrade…
Being a 2015 F-150, this is a retrofit Sync 3?
These are the installed files:
5U5T-14G381-EK
5U5T-14G391-CL
4U5T-14G423-CA
4U5T-14G421-CAC
4U5T-14G421-CBC
4U5T-14G421-CCC
4U5T-14G421-CDC
4U5T-14G421-CEC
4U5T-14G421-CFC
4U5T-14G421-CGC
4U5T-14G421-CHC
4U5T-14G421-CJC
4U5T-14G422-CAF
4U5T-14G422-CBF
4U5T-14G422-CCF
The APIM is not MY20+. The firmware is Pre-MY18.5.
I’m not sure i would 100% say it’s not MY20, considering the risk, but i’ll leave that to you.
I think it’s safe to say that based on the information provided by the incomplete log, the APIM does not seem to be MY20, without 100% certainty.
But again, as always, we can’t be sure until both the APIM and screen are physically checked.
And as always, it’s up to the user to accept the risk or not.
