Interrogator USB stuck at "Updating System Software"
I am hoping someone can help me with an issue I am having trying to run the interrogator utility on my 2016 Lincoln MKX. I bought the car used so thought it would be best to be safe. I am using a 32 GB Kingston USB, and have tried creating it with both the install pathway and through the utilities section. After starting the car and letting the system initialize, I insert the USB. “Updating system software” pops up and it just remains stuck there. I have waited for 20 minutes with no changes, and no xml file on the USB. Attemping to upgrade to 3.3.19052. I would appreciate your advice.
Install Type: Unknown
Old SYNC Version: 1.0.15139
New SYNC Version: 3.3.19052
No update file
Perform a master reset.
What interrogator package are you using?.
If you do not have luck running it, you can go into bezel diagnostics to see what the APIM model is, but based on it running Sync3 1.x I would guess it’s the original one.
Thanks for your reply, I did a master reset and it was unsuccessful. I am unsure of what interrogator package is being used.
I did end up using bezel diagnostics and found it was not MY20. Thanks for your help!
Sync 3.0 version 1, not surprising. You have to reformat to go to Sync 3.2+.
