Invalid name space
so i’m having problems with the cyanlabs application. when i go to try and plug in my usb drive i get a big red message that would display ( invalid namespace ) i have no clue what that mean. i’m using windows 11 i even download windows 10 i still have the same problem. does anybody else have the same problem.
Try typing in the suggested item here in Command Prompt.
Appears to be a rare conflict between Syn3Updater and some computer systems.
i copied and past what you gave me and this is what popped up
Ok…it has worked for some apparently. A lot of other advice if you do a search. I don’t think it is an issue with Syn3Updater, more to do with a computer setting.
Does the path C:\windows\system32\wbem\ exist on your W10 computer?.
Have you ran the command from an elevated CMD terminal (administrator)?, I think you have not…
correct, it wouldn’t be defaulted to C:\Isers\DERRICK if he did
