Inverted Dual Driver Passenger Temperature on climate repeater FIX
On RHD vehicles, climate repeater is showing inverted temperatures for driver and passenger side. This is a bug on Ford’s side but they didn’t bothered fixing it, instead choosing to just disable the climate repeaters on RHD vehicles. Very irresponsible!
SYNC Region: ANZ
Old SYNC Version: 3.4.00000
What’s you point? Did you need help fixing this?
It’s not necessarily a bug, you’re putting Sync3 in a vehicle that didn’t come with it.
It’s only a bug if it doesn’t work in a vehicle that came with it from the factory and you’re still running a supported version of Sync3.
As an example, a 2019 Escape came with Sync 3.0.x, if the APIM is reformatted to go to 3.4.x and something doesn’t work afterwards any Ford dealer that opens a case with Ford will get told they don’t support modified hardware.
FMods has a fix for this.
