After the upgrade, the screen when booted goes black with the blue fade along the bottom which was expected, however when unlocking the car and opening the door, the IPC shows the above and nothing else, as if it’s missing the Ford logo file or something.
Is this normal for a MK3 with Sync 3 upgrade? I feel like I changed a config option but can’t remember what it was…
Oh ok, so your unit was converted to Sync3… “Sync3 upgrade” has now a different meaning.
It may be related to that, have you reformatted the unit?.
Keep in mind that some operations with Sync3 mag revert back some asbuilt values to their defaults, so maybe you should double check that’s not the case.
