Recently I have acquired Ford Fiesta 2019. Upon examining car I discovered SYNC 3 version was outdated as well as navigation. I took steps to update SYNC as it was described on Ford’s official website, but when I turned to maps it got complicated. Searching for solution I stumbled upon this brilliant website and found my solution, but I am unsure if AIPM has My20 protection. I followed instructions to create interrogator log and it said that it is NOT My20 protected , but I wanted another opinion so I will provide the log below. The car is 2018 model, manufactured in 2019 which should indicate it is not My20 protected but I cannot know if previous owner had retrofitted or replaced SYNC. Any information would be helpful ![]()
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2023-09-14” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>WF0JXXGAHJKK18524</p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNCGEN3</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:ResponseNU5T-14G381-AA</d2p1:Response>
</d2p1:DID>
d2p1:Response315535542d3134473432312d424144000000000000000000315535542d3134473432312d424244000000000000000000315535542d3134473432312d424344000000000000000000315535542d3134473432312d424444000000000000000000315535542d3134473432312d424544000000000000000000315535542d3134473432312d424644000000000000000000315535542d3134473432312d424744000000000000000000315535542d3134473432312d424844000000000000000000315535542d3134473432312d424a44000000000000000000315535542d3134473635382d414800000000000000000000345535542d3134473432332d414300000000000000000000355535542d3134473339312d415400000000000000000000345535542d3134473432322d424141000000000000000000345535542d3134473432322d424241000000000000000000345535542d3134473432322d424341000000000000000000345535542d3134473432322d424441000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Responsecc767535</d2p1:Response>
</d2p1:DID>
d2p1:Response4844f94a</d2p1:Response>
</d2p1:DID>
d2p1:Response806a049a50027c4441c2</d2p1:Response>
</d2p1:DID>
d2p1:Response474d000ac08a0890a8b84e04</d2p1:Response>
</d2p1:DID>
d2p1:Response0000010000</d2p1:Response>
</d2p1:DID>
d2p1:Response01001d82010100</d2p1:Response>
</d2p1:DID>
d2p1:Response190819082653</d2p1:Response>
</d2p1:DID>
d2p1:Response80</d2p1:Response>
</d2p1:DID>
d2p1:Response0b0533000000006428000056565d0061</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-1U5T-14G371-DA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGU5T-14G380-FD</d2p1:Response>
</d2p1:DID>
d2p1:ResponseKU5T-14G371-GDE</d2p1:Response>
</d2p1:DID>
d2p1:Response1U5T-14G375-HA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseNY2E00KF</d2p1:Response>
</d2p1:DID>
d2p1:Response00</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response1U5T-14G374-DA</d2p1:Response>
</d2p1:DID>
d2p1:Response</d2p1:Response>
</d2p1:DID>
d2p1:Response78:04:73:a9:bd:95</d2p1:Response>
</d2p1:DID>
d2p1:Response78:04:73:a9:bd:96</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2023-09-14T20:03:40+00:00” RAM=“983076864” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.1G” available=“60M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.3G” available=“66M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.1G” available=“68M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.4G” available=“42M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.0G” available=“69M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.6G” available=“17M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“24M” available=“488K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.8G” available=“81M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.8G” available=“107M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.5G” available=“269M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.6G” available=“278M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.1G” available=“248M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“3.3G” available=“182M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.9G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“1003M” available=“21M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“574M”/>
<d2p1:PartitionHealth type=“/fs/mp/resources” total=“72M” available=“332K”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“54G” available=“15G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Install Type: Unknown
Old SYNC Version: 3.3
New SYNC Version: 3.4.22200
