Is my unit have nav or not
according to the interogation file it said
APIM Type: Navigation
but my car has never have nav feature in sync screen.
i don’t know if my car has nav and it simply disabled in asbuilt?
2018 ecosport
Version JR3T-14G381-AS
APIM Model: HN1T-14G371-EEC
and asbuilt
APIM AsBuilt
DE00: 0A6A0186500008060080
DE01: 564D0104C08201802C800105
DE02: 0000010000
DE03: 00000082070001
DE04: 1900190026AC
DE05: 40
DE06: 0E04330000000080E80000565664006B
i would like to know before i purchase a cable to use forscan
thanks for your help
SYNC Region: ROW
Old SYNC Version: 3.0.19205
no
Syn3 Updater Version: 2.12.5.0 (stable)
Version: 3.0.19205
Region: ROW
Partition Type: GPT
VOICE=5U5T-14G391-BS_1660772122000.TAR.GZ
; CyanLabs Syn3Updater 2.12.5.0 Stable - reformat  Mode - Sync 3.4.23188 ROW
FILES (5)
1u5t-14g386-cb.tar.gz (8,5MB)
5U5T-14G391-BS_1660772122000.TAR.GZ (1,4GB)
[24/02/2024 10:30:43 SA] Selected Region: ROW - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[24/02/2024 10:30:43 SA] Install Mode: Auto-Detect (reformat) Forced: False
[24/02/2024 10:30:43 SA] MY20 Protection: Auto-Detect
[24/02/2024 10:30:43 SA] Formatting USB drive
[24/02/2024 10:30:43 SA] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[24/02/2024 10:30:50 SA] Checking Existing File: 1u5t-14g386-cb.tar.gz
[24/02/2024 10:30:50 SA] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[24/02/2024 10:30:50 SA] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[24/02/2024 10:30:50 SA] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[24/02/2024 10:30:50 SA] Checking Existing File: 5U5T-14G391-BS_1660772122000.TAR.GZ
[24/02/2024 10:30:57 SA] Validated: 5U5T-14G391-BS_1660772122000.TAR.GZ (Skipping Download)
[24/02/2024 10:30:57 SA] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[24/02/2024 10:30:57 SA] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[24/02/2024 10:30:57 SA] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[24/02/2024 10:31:00 SA] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[24/02/2024 10:31:00 SA] Preparing USB drive
[24/02/2024 10:31:00 SA] Checking Existing File: 1u5t-14g386-cb.tar.gz
[24/02/2024 10:31:00 SA] Copying: 1u5t-14g386-cb.tar.gz
[24/02/2024 10:31:01 SA] Validating: 1u5t-14g386-cb.tar.gz
[24/02/2024 10:31:02 SA] Copied: 1u5t-14g386-cb.tar.gz
[24/02/2024 10:31:02 SA] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[24/02/2024 10:31:02 SA] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[24/02/2024 10:31:02 SA] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[24/02/2024 10:31:02 SA] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[24/02/2024 10:31:02 SA] Checking Existing File: 5U5T-14G391-BS_1660772122000.TAR.GZ
[24/02/2024 10:31:02 SA] Copying: 5U5T-14G391-BS_1660772122000.TAR.GZ
[24/02/2024 10:33:56 SA] Validating: 5U5T-14G391-BS_1660772122000.TAR.GZ
[24/02/2024 10:33:59 SA] Copied: 5U5T-14G391-BS_1660772122000.TAR.GZ
[24/02/2024 10:33:59 SA] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[24/02/2024 10:33:59 SA] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[24/02/2024 10:34:06 SA] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[24/02/2024 10:34:06 SA] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[24/02/2024 10:34:06 SA] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[24/02/2024 10:34:06 SA] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[24/02/2024 10:35:49 SA] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[24/02/2024 10:35:51 SA] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[24/02/2024 10:35:51 SA] Generating reformat.lst
[24/02/2024 10:35:52 SA] Generating autoinstall.lst
[24/02/2024 10:35:52 SA] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
So when you uploaded 3.4.23188 to the car without maps everything worked ok…radio, music, phone, voice etc?
Where are you situated?
This will come down to what part of the world the car is located in.
HN1T-14G371-EEC in the DB is a 32Gb unit which would work for say NA US/Canada maps but not for the EU. EU units have 64Gb of storage.
yes it worked no calm screen tho and no ac controls on sync (my ac is automatic one)
i’m in south east asia
my unit is 32 gb and i am in south east asia
thanks for the info
ps: if i go ahead and load the version with map on my car will it brick the apim unit?
The HN1T-14G371-EEC is not a MY20+ unit therefore can be reformatted. The NAV is turned off in the asbuilt. You can turn it on and load the appropriate maps for your region if you like. You will need FORScan and one of the recommended adapters. You can find the recommended adapters and other FORScan information in the Information section of the forum.
in forscan app i go to the apim asbuilt one and modify the value there right?
also which value i need to change because there is many related to nav and i’m confused
also thanks
Location
DE00/7D0-01-02: x*xx-xxxx-xxxx
Values
0=USB2 Disabled, Navigation Disabled, Rear EFP Disabled
1=USB2 Disabled, Navigation Disabled, Rear EFP Enabled
2=USB2 Disabled, Navigation Enabled (Telenav Common HMI), Rear EFP Disabled
3=USB2 Disabled, Navigation Enabled (Telenav Common HMI), Rear EFP Enabled
4=USB2 Disabled, Navigation Enabled (NNG External HMI), Rear EFP Disabled
5=USB2 Disabled, Navigation Enabled (NNG External HMI), Rear EFP Enabled
6=USB2 Disabled, Navigation Application Enabled (External Telenav HMI), Rear EFP Not Available
7=USB2 Disabled, Navigation Application Enabled (External Telenav HMI), Rear EFP Available
8=USB2 Enabled, Navigation Disabled, Rear EFP Disabled
9=USB2 Enabled, Navigation Disabled, Rear EFP Enabled
A=USB2 Enabled, Navigation Enabled (Telenav Common HMI), Rear EFP Disabled
B=USB2 Enabled, Navigation Enabled (Telenav Common HMI), Rear EFP Enabled
C=USB2 Enabled, Navigation Enabled (NNG External HMI), Rear EFP Disabled
D=USB2 Enabled, Navigation Enabled (NNG External HMI), Rear EFP Enabled
E=USB2 Enabled, Navigation Application Enabled (External Telenav HMI), Rear EFP Not Available
F=USB2 Enabled, Navigation Application Enabled (External Telenav HMI), Rear EFP Available
Notes
NAV APIM is physically different, enabling navigation on a NON-NAV APIM will cause errors.
*USB2 setting has been removed in Sync 3.4.
i saw my asbuilt DE00 has that digit set to A which is enabled right?
This translates to:
7D0-01-01: 0A6A-0186-50xx
7D0-01-02: 0008-0600-80xx
You presently have a ‘0’ programmed at 7D0-01-02: x*xx-xxxx-xxxx.
how do i know which nav type i need
You are ROW which is NNG.
okay thanks that clear things up so i need to edit the value from 0 to 4 for my car
i’m gonna have the cable soon to so it
