Hi team, I need your advice about an issue happening with the update in subject.
I am working with version No Maps, with region ANZ
I tried this:
Attempted to upgrade with auto detect install, once plugged the USB appears the message Updating Software in the screen but nothing changes after 2 hours.
Attempted to upgrade with reformat option, and displayed Error 18000913673 asking to redownload files, I did it twice but getting same error
I will attempt to downgrade to version 3.319052 and then use option reformat installing version 3.4.22020, let me know if this step does it make sense or if I am missing something else to do correctly
Thanks in advance
SYNC Region: Australia, New Zealand, South America
Navigation Variant: No
Old SYNC Version: 3.4.20220
New SYNC Version: 3.4.20220
Error 18000913673 when attempting to run a reformat option
Thanks man really appreciated , another favor, just to recheck, I did the update via reformat option to version 3.4.22020 but I had to remove Gracenote and voice from the install due error MEM03, basically I need to do a new autoinstall but only selecting both files gracenotes and voice and unmark Apps, is this correct?
You can try then installing ANZ packages, but replacing VOICE with this package 5U5T-14G391-CP. That’s for NA, contains Spanish and I would suspect English too. I’m sure about Spanish, not sure about English though.
That way you could have GN, Voice and APPS.
