Hello Guys
This is the first post for me and the first sync3 installation attempt as well
I retrofitted a Gen4 MY20 Sync 3 (L2G2-14G370-BBH) on my 2013 Ford Edge Limited , played with the AsBuilt Data , but I’m still suffering some problems
1- The on-screen climate controls are not working greyed out , as well as the vehicle setting and the ambient control setting, and the master reset option
2- Reverse camera is not working , whatever i tried to change in the setting ( Could be a faulty camera ) but I have to mention
3- The APIM Display wont turn off after turning the vehicle off , and when turning it off manually , i can still see the backlight , which means its not completely turning off
4- Whenever I set the clock , it will go back to 12:00 immediately ( Note : the GPS Antenna still on order , now the module is not connected to any GPS Antenna)
5-
Vehicle VIN:2FMDK4KC7DBA12771
Please I need your support to solve these issues specially the climate controls and the display off
SYNC Region: ROW
Old SYNC Version: 3.0.2121
Syn3 Updater Version: Ver 2
https://drive.google.com/file/d/1td4VbIS9H0byaV_u_mcLtm1-DyPxGk2J/view?usp=sharing
