Hi. I have a focus 2019 active X… probably like most the ford site is failing to allow f9 maps, although I do have a 3.4 20136 …so can i just up date the maps to f9 …not the sync firmware, as im still have manufactures warranty…
You can, but since map installation requires reformat, you will actually reinstall the whole system by doing that… You can stay at your current build if you want, I think that’s listed in Syn3Updater.
