I want to update to 3.4 or 4 Sync with only Cyprus map ,but I don’t want to do some thing and I lose my System or brick it
I have MacBook and I have USB
You can only update to Sync 3.4 versions, not Sync 4, without replacing the hardware. Cyprus is included in EU maps. However, being that you have a 2019 Lincoln Navigator, you cannot install all of the EU maps due to storage limitations.
Thank you for your reply, the problem is if some thing happens to the car system there is no dealership or any agency for Lincoln here , and when I went to ford dealership here they say they will not accept any work or Service for Lincoln…that why I need to be sure that the Updates get well and done without any problems… what I need really is the Cyprus map only ,if its possible to have the map without upgrading the whole system.
on my car I already have the Asia map with middle east , I don’t need them ,i only need to have Cyprus map ,if there is a way to delete the old map and install Cyprus map only.
I did the update today and I confirm that I have now 3.4 V 19200
but the map is not working and the screen shrink to small box …
thank you for your help and I think now I need Forscan and adjustments to make the screen fit to the 10"
now I-am in (small screen not 10" as my system is ) changing the theme to Lincoln may20L not helping some time its come black screen with no way to change or control until you put the car off and return after 5 to 10 min …Cyprus map not working too , now I am searching (how to return the system back as it’s was
I did not find any OBDlink here ,I ordered one from amazon I will update you with the results when I complete the process…but is there a way to return back to 3.0 17302 using USB ?
