Manual installation fails after ~7 minutes with error "Error in 1U5T-14G658-AH_1644006443000.TAR.GZ :
I have done evertyhing according to instructions and followed step-by-step guide for Mac users. Tried it five times with two different USB sticks and still got the same error. Installation works fine for first 7-8 minutes and then I get red screen with error ""Error in 1U5T-14G658-AH_1644006443000.TAR.GZ : "
Old SYNC Version: 1.0
Share:
  • all .lst files located in the USB’s root
  • a screenshot of the SyncMyRide folder’s content
autoinstall.lst (149 Bytes)
reformat.lst (174 Bytes)
Assuming there’s not enough space on the APIM, edit the reformat.lst file and remove these 2 sentences:
If that works, create, run and share the interrogator log output (XML file).
Thanks! It all works fine now!
You are welcome. Then my suspicion that you do not have enough space was correct.
Now, you have 2 packages “missing” from the APIM, Gracenotes (media artwork) and ENH_DAB.
The reason I asked for the interrogator output was to see how much free space the unit has, based on that you may or may not install any other packages.
Question: what language do you need?. You currently have installed a 1.5GB VOICE package (which takes more space on the APIM since the package is compressed).
