Map Spinning/GPS issues
It’s so hit and miss, yesterday I didn’t have any wandering but the spins were really bad. The as built is based on a few like for like mondeos with sync3 from factory. I have pulled another for comparison and in one of the blocks I currently have 566E and the one I have just obtained with same wheel size has 566D. There are a few other little bits that differ too. Will see what it does.
As for gps antenna location, it’s currently behind my ipc. Should I move it to behind sync screen? As I say it’s brand new from Ford and is about a month old now. the connection lead between apim and gps antenna is also brand new. Replaced at the same time.
Thanks
