Maps not updating after 3.4 install
I have updated from 2.2 to 3.4 and all works except navigation, it does not show a version, I did select navigation when I began
log.txt (11.3 KB)
Navigation Variant: Yes
Old SYNC Version: 2.2 16280
New SYNC Version: 3.4 22020
no errors.
Syn3 Updater Version: 2.10.8
https://cyanlabs.net/fhub/syn3-updater-log/?uuid=1ecaea6f-c1b0-6892-b845-0242ac120004
So you saw the green screen.
Have hoy master reset?.
If so, create and run an interrogator USB against the APIM, then post the output here
If there is not maps version number then there are no maps installed. Or at least no map license. The file does show up in the log. Like mentioned above by @SaNdMaN and in the instructions, perform a Master Reset.
