MEM ERR 003
Hi All
I have searched previous topics on this subject, but not winning for a solution.
also… When i try “Master Reset”, my unit just freezes.
AND, When i switch my car on, Sync asks me about automatic updates EVERY TIME. Even if i confirm, it still asks me the next time again).
SYNC Region: ROW
Old SYNC Version: 3.4.2551
New SYNC Version: 3.4.2551
MEM ERR003
Branch: Beta
Operating System: Microsoft Windows 11 Home Single Language (2009)
Version: 3.4.22251
Region: ROW
Model: SanDisk Cruzer Glide 3.0 USB Device
; CyanLabs Syn3Updater 2.11.8.0 Beta - Autoinstall Mode - Sync 3.4.19200 ROW
[SYNCGen3.0_3.0.1_PRODUCT]
Item1 = MAP_LICENSE - 4U5T-14G424-FFK.tar.gz
Open1 = SyncMyRide\4U5T-14G424-FFK.tar.gz
Item2 = VOICE - 4U5T-14G391-FJ_1552513905000.TAR.GZ
Open2 = SyncMyRide\4U5T-14G391-FJ_1552513905000.TAR.GZ
[SYNCGen3.0_3.0.1]
Item1 = MAP - 4U5T-14G421-FFK.tar.gz
Open1 = SyncMyRide\4U5T-14G421-FFK.tar.gz
Item1 = APPS - 5U5T-14G381-CD_1564401086000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G381-CD_1564401086000.TAR.GZ
Item2 = ENH_DAB - 1U5T-14G658-AD_1544799507000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G658-AD_1544799507000.TAR.GZ
FILES (5)
5U5T-14G381-CD_1564401086000.TAR.GZ (828,2MB)
1U5T-14G658-AD_1544799507000.TAR.GZ (61,8MB)
4U5T-14G391-FJ_1552513905000.TAR.GZ (1,3GB)
4U5T-14G421-FFK.tar.gz (1,1GB)
4U5T-14G424-FFK.tar.gz (1,7KB)
[2023/04/03 08:35:29] Selected Region: ROW - Release: Sync 3.4.19200 - Map Version: Keep Existing Maps
[2023/04/03 08:35:29] Install Mode: Auto-Detect (autoinstall) Forced: False
[2023/04/03 08:35:29] MY20 Protection: Enabled
[2023/04/03 08:35:29] Formatting USB drive
[2023/04/03 08:35:29] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2023/04/03 08:35:37] Checking Existing File: 5U5T-14G381-CD_1564401086000.TAR.GZ
[2023/04/03 08:35:39] Validated: 5U5T-14G381-CD_1564401086000.TAR.GZ (Skipping Download)
[2023/04/03 08:35:39] Checking Existing File: 1U5T-14G658-AD_1544799507000.TAR.GZ
[2023/04/03 08:35:40] Validated: 1U5T-14G658-AD_1544799507000.TAR.GZ (Skipping Download)
[2023/04/03 08:35:40] Checking Existing File: 4U5T-14G391-FJ_1552513905000.TAR.GZ
[2023/04/03 08:35:44] Validated: 4U5T-14G391-FJ_1552513905000.TAR.GZ (Skipping Download)
[2023/04/03 08:35:44] Preparing USB drive
[2023/04/03 08:35:44] Checking Existing File: 5U5T-14G381-CD_1564401086000.TAR.GZ
[2023/04/03 08:35:44] Copying: 5U5T-14G381-CD_1564401086000.TAR.GZ
[2023/04/03 08:36:23] Validating: 5U5T-14G381-CD_1564401086000.TAR.GZ
[2023/04/03 08:36:36] Copied: 5U5T-14G381-CD_1564401086000.TAR.GZ
[2023/04/03 08:36:36] Checking Existing File: 1U5T-14G658-AD_1544799507000.TAR.GZ
[2023/04/03 08:36:36] Copying: 1U5T-14G658-AD_1544799507000.TAR.GZ
[2023/04/03 08:36:39] Validating: 1U5T-14G658-AD_1544799507000.TAR.GZ
[2023/04/03 08:36:40] Copied: 1U5T-14G658-AD_1544799507000.TAR.GZ
[2023/04/03 08:36:40] Checking Existing File: 4U5T-14G391-FJ_1552513905000.TAR.GZ
[2023/04/03 08:36:40] Copying: 4U5T-14G391-FJ_1552513905000.TAR.GZ
[2023/04/03 08:37:47] Validating: 4U5T-14G391-FJ_1552513905000.TAR.GZ
[2023/04/03 08:38:08] Copied: 4U5T-14G391-FJ_1552513905000.TAR.GZ
[2023/04/03 08:38:08] Checking Existing File: 4U5T-14G421-FFK.tar.gz
[2023/04/03 08:38:08] Copying: 4U5T-14G421-FFK.tar.gz
[2023/04/03 08:39:06] Validating: 4U5T-14G421-FFK.tar.gz
[2023/04/03 08:39:25] Copied: 4U5T-14G421-FFK.tar.gz
[2023/04/03 08:39:25] Checking Existing File: 4U5T-14G424-FFK.tar.gz
[2023/04/03 08:39:25] Copying: 4U5T-14G424-FFK.tar.gz
[2023/04/03 08:39:25] Validating: 4U5T-14G424-FFK.tar.gz
[2023/04/03 08:39:25] Copied: 4U5T-14G424-FFK.tar.gz
[2023/04/03 08:39:25] Generating Autoinstall.lst
[2023/04/03 08:39:25] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Hello.
What you are describing suggests you have an unhealthy APIM.
But, lets check what’s on the unit: create and run an interrogator log against it, post back the results.
VIN: AFAJXXMJWJLY36406
Version NU5T-14G381-AB
APIM Model: LU5T-14G371-FKC
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 18G
2023/04/03 15:28:04 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 27M / 4.5G
/fs/Nuance/ = 7.0M / 1.7G
/fs/rwdata/ = 0 / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 18G / 25G
Installed Packages
4U5T-14G421-FAF
1U5T-14G658-AH
5U5T-14G391-FT
4U5T-14G424-FAH
APIM AsBuilt
DE00: 0A6A01C218040A4A4090
DE01: 53460104C002000004840105
DE02: 0000000200
DE03: 010030002B0008
DE04: 17FE180E2BD4
DE05: 80
DE06: 1404330000000016760000565689005C
Have tried the downgrade option on the Updater Tool, and i get now ERR08 .
(I managed to remove gracenotes before trying the downgrade)
Thank you.
Well… this is turning into a gray area…
APIM seems fine, lots of free space, nothing that would trigger a MEM03 error.
This keeps pointing to an unhealthy APIM.
Since you are using a Sandisk USB pendrive, that does not seem to be the issue. But you can always try another drive to see if that makes a difference.
If you have a 2020+ APIM why would you do a downgrade option with the updater tool? Seems your APIM is toast.
I’ve just noticed this… use the stable version…
Not that it would matter, but use the stable version now…
You are making things harder on yourself… error is not based on free space, so removing GN won’t help…
Re run the interrogator log to see where we stand…
APIM Size: 32GB
2023/04/04 09:36:26 +00:00
(/fs/rwdata/quip = 0 / 35M
Installed Packages
4U5T-14G421-FAF
1U5T-14G658-AH
5U5T-14G391-FT
4U5T-14G424-FAH
APIM AsBuilt
DE02: 0000000200
DE04: 17FE180E2BD4
DE05: 80
I thought by downgrading, it would give me an opportunity to do a master reset. Master reset freezes the system :frowning:
Other than removing the fuse overnight, I do not know what else you could try.
Do you have forscan and an adapter?, I think you can force a reset via Forscan (not 100% sure though, or if it even work on yours).
Try holding down the power and fast forward button to see if that will restart it.
That does restart it, but still no luck with master reset
I’ll try the fuse option, thanks.
Dont have forscan and an adapter im afraid.
Its still under warranty, so may need to try that route…
In your installation in the first post, the files do not match what you presently have installed in the unit. If you have a mixture of different version files, this can cause issues with the system, especially the navigation files. This looks like a failed installation from the start. No wonder you have issues.
You need to install the proper maps package:
4U5T-14G421-FAK 4.9Gb Sync3 v3.2. 22245 CAM (21Q4), Caribbean (21Q4), India (21Q4), Israel (21Q4), MENA (21Q4), SAF (21Q4), SEA (21Q4)
You have the space to install the entire package, you should do so.
DO NOT downgrade your APIM to Sync 3.3. It is not necessary, and if you have a 10" screen you will have issues. You don’t state what vehicle or year this is…
5346 is SOUTH AFRICA. You are trying to install this map from the -FAK package. This was not successful. You presently have the -FAF package installed with a later license.
Thanks, but what do i do if i keep getting the MEMERR03 Error when trying to install?
The navigation installed is straight from the Sync3 Updater tool for South Africa.
So should i just try update the maps only perhaps?
MAPS currently doesnt work in the can. Clicking on Navigation just does nothing.
Would love to just reformat the whole thing, but need to keep my warranty.
You cannot reformat the unit as it is MY20+.
yes
Here is the issue with your APIM, you have no space left in the /fs/rwdata partition, therefore the APIM cannot process updates or save data settings. Since you have a MY20 APIM you cannot reformat the unit to fix it. There is nothing you can do to recover it without either a reformat or jailbreak.
Take it in to Ford Service and get a new one.
