My Solution for Sync 3 Screen flickering on Focus MK3
Hey, I found a solution to the Sync 3.4 Build 21194 flickering screen issue in Fcous mk3
Important: You do all the instructions on your own responsibility, there is no guarantee that it will work exactly for you as it did for me. So I am not responsible for your actions.
ForScan is required, I have done the following:
  1. Program APIM via Forscan with the following settings:
  2. ambilight: enable (write setting, sync 3 restarts)
  3. ambilight type: Single Color (Write setting, Sync 3 restarts)
Please make sure whether you also have single color or multicolor, with me it is only single color.
  1. iliatration gateway strategy: C1MCA (write setting, Sync 3 restarts)
  2. After the restart, the Auto Dim function was available for a short time, I then switched it off and ended the programming in the Foscan.
After the next restart of Sync, the Auto Dim option was no longer present in the options, but it remained disabled and the flickering has gone away so far.
Hope it maybe helps you.
