My20 apim update via fmods
Hi there I have just jailbroken my apim and I am planning to use the reformat tool from them to update my unit to 3.4 - my question is when I create my files from syn3updater it has detected my unit is my20 and it has made it auto install instead of reformat also I get a pop up error in red saying you can’t do the following … I can’t upgrade from 3.0 to 3.2 or higher? Will this still work with fmods
Install Type: OEM Replacement
Old SYNC Version: 3.0.23219
New SYNC Version: 3.0.23219
None
Hello.
:warning: We do not support jailbreak, you should be asking the procedure’s specifics in their support forum/discord.
Having said that…
Well, since you can’t reformat MY20 units with Syn3updater that makes sense, right?. You can only autoinstall with syn3updater for MY20 units.
You can’t with Syn3updater, no.
Upgrading to 3.4 using their reformat package instead of Ford’s?, yes it should work since it’s specifically designed for that. Again, contact them if you have doubts about using their tool.
Thank you
