Trying to update to 23088 and maps. The MY20 Interrogator runs, but the XML isn’t recognized. The APIM was recently replaced by Ford.
I install the files on a USB drive, run the interrogator until the APIM reboots, but Syn3Updater says it cannot determine if I have MY20 and aborts.
Install Type: OEM Replacement
Old SYNC Version: 3.4.22152
New SYNC Version: 3.4.22152
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2023-07-25" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>1FTEX1EP1LKF03512</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue="919f1308"/>
<d2p1:DTC DTCValue="c1510008"/>
<d2p1:DTC DTCValue="c1840008"/>
<d2p1:DTC DTCValue="90870148"/>
<d2p1:DTC DTCValue="c4520008"/>
<d2p1:DTC DTCValue="c1620008"/>
<d2p1:DTC DTCValue="e1000008"/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>NU5T-14G381-AB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>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</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>V2680582</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>90:48:46:ec:15:ce</d2p1:Response>
</d2p1:DID>
<d2p1:Response>90:48:46:ec:15:cf</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2023-07-25T11:52:05+00:00" RAM="975220736" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="12M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.4G" available="12M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.4G" available="10M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="951M" available="2.9M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="8.6M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.8G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.7G" available="17M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.4G" available="6.7M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.6G" available="15M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.1G" available="10M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="2.5G" available="24M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.7G" available="7.0M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="775M" available="5.8M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="689M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="84M"/>
<d2p1:PartitionHealth type="/fs/images/" total="25G" available="3.0G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
