Nanigation volume
on sync3 Is the a way to put the Navigation volume on the screen ?
Install Type: OEM Replacement
Old SYNC Version: 3.2
I have NO error
Syn3 Updater Version: 2.13.2.0
I dont have the log
There is not, unfortunately…at least permanently. When the nav voice is speaking you can adjust the volume.
There is no need for it as once you set the Nav volume to a level to suit you it will remain set in the same way your radio, music and phone volume is set.
You will only see the volume bar when resetting the level and in the case of phone and Nav whilst the voice is actually addressing you as you are aware.
