Nav Map Blank
Maps are blank, cursor shows up and I am able to search for POI (restaurants, fuel, etc…) but everything shows its near me and the sync voice tells me “route guidance failed” I tried to reload the software via usb drive and get the error “PKG_ERR04”
Old SYNC Version: 3.0.19205
PKG_ERR04
Version: 3.0.19205
; CyanLabs Syn3Updater 2.12.2.0 Stable - reformat  Mode - Sync 3.4.23188 NA
FILES (18)
[11/18/2023 1:48:23 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: NA - 2023-11-03 - 1699040980
[11/18/2023 1:48:23 PM] Install Mode: Auto-Detect (reformat) Forced: False
[11/18/2023 1:48:23 PM] MY20 Protection: Auto-Detect
[11/18/2023 1:48:23 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[11/18/2023 1:48:23 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[11/18/2023 1:48:23 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[11/18/2023 1:48:23 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[11/18/2023 1:48:23 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[11/18/2023 1:48:24 PM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[11/18/2023 1:48:24 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[11/18/2023 1:48:26 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[11/18/2023 1:48:26 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[11/18/2023 1:48:28 PM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[11/18/2023 1:48:28 PM] Checking Existing File: 4U5T-14G424-CF_1682464057000.TAR.GZ
[11/18/2023 1:48:28 PM] Validated: 4U5T-14G424-CF_1682464057000.TAR.GZ (Skipping Download)
[11/18/2023 1:48:28 PM] Checking Existing File: 4U5T-14G421-CEF_1682461522000.TAR.GZ
[11/18/2023 1:48:31 PM] Validated: 4U5T-14G421-CEF_1682461522000.TAR.GZ (Skipping Download)
[11/18/2023 1:48:31 PM] Checking Existing File: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[11/18/2023 1:48:34 PM] Validated: 4U5T-14G421-CBF_1682461295000.TAR.GZ (Skipping Download)
[11/18/2023 1:48:34 PM] Checking Existing File: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[11/18/2023 1:48:36 PM] Validated: 4U5T-14G421-CAF_1682461100000.TAR.GZ (Skipping Download)
[11/18/2023 1:48:36 PM] Preparing USB drive
[11/18/2023 1:48:36 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[11/18/2023 1:48:37 PM] 1u5t-14g386-cb.tar.gz exists and validated successfully, skipping copy
[11/18/2023 1:48:37 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[11/18/2023 1:48:37 PM] PU5T-14G386-BB_1690840002000.TAR.GZ exists and validated successfully, skipping copy
[11/18/2023 1:48:37 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[11/18/2023 1:48:59 PM] 5U5T-14G391-CS_1660783942000.TAR.GZ exists and validated successfully, skipping copy
[11/18/2023 1:48:59 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[11/18/2023 1:49:32 PM] 4U5T-14G423-CC_1615429225000.TAR.GZ exists and validated successfully, skipping copy
[11/18/2023 1:49:33 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[11/18/2023 1:50:23 PM] NU5T-14G381-AD_1689364279000.TAR.GZ exists and validated successfully, skipping copy
[11/18/2023 1:50:23 PM] Checking Existing File: 4U5T-14G424-CF_1682464057000.TAR.GZ
[11/18/2023 1:50:23 PM] 4U5T-14G424-CF_1682464057000.TAR.GZ exists and validated successfully, skipping copy
[11/18/2023 1:50:23 PM] Checking Existing File: 4U5T-14G421-CEF_1682461522000.TAR.GZ
[11/18/2023 1:51:29 PM] 4U5T-14G421-CEF_1682461522000.TAR.GZ exists and validated successfully, skipping copy
[11/18/2023 1:51:29 PM] Checking Existing File: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[11/18/2023 1:52:36 PM] 4U5T-14G421-CBF_1682461295000.TAR.GZ exists and validated successfully, skipping copy
[11/18/2023 1:52:36 PM] Checking Existing File: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[11/18/2023 1:53:34 PM] 4U5T-14G421-CAF_1682461100000.TAR.GZ exists and validated successfully, skipping copy
[11/18/2023 1:53:34 PM] Generating reformat.lst
[11/18/2023 1:53:34 PM] Generating autoinstall.lst
[11/18/2023 1:53:34 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Have you master reset?
Plus, you are using a cutdown map version and maybe you are not installing what’s needed for your region.
Yes, a master reset was done and the maps are still blank. I’m not sure what you mean about a cutdown map. I downloaded NA, but really just need USA.
Edit: I also have the original log from when I upgraded from 3.0 originally if you need that.
That’s a cut down map version, so correct that in the settings and try again.
You are not feeding syn3updater correct information, that’s possibly why you are having issues.
Settings on my vehicle or in creating a new drive using the Syn3 Updater tool?
In your original post you state that your sync Navigation Variant is Non Nav. Was that a typo?
If not and you are trying to install maps then that is the issue.
Sorry, that is a typo. Its got a nav system.
The tool.
I updated the tool, but now i’m getting a signing error SIGN_ERR01. Here is the log info
Version: 3.4.23188
; CyanLabs Syn3Updater 2.12.2.0 Stable - Autoinstall Mode - Only Update Maps NA
[SYNCGen3.0_3.0.1_PRODUCT]
Item2 = MAP_LICENSE - 4U5T-14G424-CF_1682464057000.TAR.GZ
Open2 = SyncMyRide\4U5T-14G424-CF_1682464057000.TAR.GZ
Item3 = MAP - 4U5T-14G421-CDF_1682463264000.TAR.GZ
Open3 = SyncMyRide\4U5T-14G421-CDF_1682463264000.TAR.GZ
[SYNCGen3.0_3.0.1]
Item1 = VOICE_NAV - 4U5T-14G422-CAM_1682463335000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G422-CAM_1682463335000.TAR.GZ
Item1 = MAP - 4U5T-14G421-CBF_1682461295000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G421-CBF_1682461295000.TAR.GZ
Item2 = MAP - 4U5T-14G421-CAF_1682461100000.TAR.GZ
Open2 = SyncMyRide\4U5T-14G421-CAF_1682461100000.TAR.GZ
FILES (6)
[11/19/2023 10:25:55 AM] Selected Region: NA - Release: Only Update Maps - Map Version: NA - 2023-11-19 - 1700411010
[11/19/2023 10:25:55 AM] Install Mode: Auto-Detect (autoinstall) Forced: False
[11/19/2023 10:25:55 AM] MY20 Protection: Auto-Detect
[11/19/2023 10:25:55 AM] Formatting USB drive
[11/19/2023 10:25:55 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[11/19/2023 10:26:02 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[11/19/2023 10:26:02 AM] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[11/19/2023 10:26:02 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[11/19/2023 10:26:02 AM] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[11/19/2023 10:26:02 AM] Checking Existing File: 4U5T-14G424-CF_1682464057000.TAR.GZ
[11/19/2023 10:26:02 AM] Downloading: 4U5T-14G424-CF_1682464057000.TAR.GZ
[11/19/2023 10:26:02 AM] Validating: 4U5T-14G424-CF_1682464057000.TAR.GZ
[11/19/2023 10:26:02 AM] Downloaded: 4U5T-14G424-CF_1682464057000.TAR.GZ
[11/19/2023 10:26:02 AM] Checking Existing File: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[11/19/2023 10:26:02 AM] Downloading: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[11/19/2023 10:29:38 AM] Validating: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[11/19/2023 10:29:42 AM] Downloaded: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[11/19/2023 10:29:42 AM] Checking Existing File: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[11/19/2023 10:29:42 AM] Downloading: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[11/19/2023 10:32:35 AM] Validating: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[11/19/2023 10:32:38 AM] Downloaded: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[11/19/2023 10:32:38 AM] Checking Existing File: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[11/19/2023 10:32:38 AM] Downloading: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[11/19/2023 10:35:11 AM] Validating: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[11/19/2023 10:35:14 AM] Downloaded: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[11/19/2023 10:35:14 AM] Checking Existing File: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[11/19/2023 10:35:14 AM] Downloading: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[11/19/2023 10:38:32 AM] Validating: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[11/19/2023 10:38:35 AM] Downloaded: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[11/19/2023 10:38:35 AM] Preparing USB drive
[11/19/2023 10:38:35 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[11/19/2023 10:38:35 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[11/19/2023 10:38:35 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[11/19/2023 10:38:35 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[11/19/2023 10:38:35 AM] Checking Existing File: 4U5T-14G424-CF_1682464057000.TAR.GZ
[11/19/2023 10:38:35 AM] Copying: 4U5T-14G424-CF_1682464057000.TAR.GZ
[11/19/2023 10:38:35 AM] Validating: 4U5T-14G424-CF_1682464057000.TAR.GZ
[11/19/2023 10:38:35 AM] Copied: 4U5T-14G424-CF_1682464057000.TAR.GZ
[11/19/2023 10:38:35 AM] Checking Existing File: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[11/19/2023 10:38:35 AM] Copying: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[11/19/2023 10:40:47 AM] Validating: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[11/19/2023 10:40:51 AM] Copied: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[11/19/2023 10:40:51 AM] Checking Existing File: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[11/19/2023 10:40:51 AM] Copying: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[11/19/2023 10:42:47 AM] Validating: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[11/19/2023 10:42:50 AM] Copied: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[11/19/2023 10:42:50 AM] Checking Existing File: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[11/19/2023 10:42:50 AM] Copying: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[11/19/2023 10:44:30 AM] Validating: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[11/19/2023 10:44:32 AM] Copied: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[11/19/2023 10:44:32 AM] Checking Existing File: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[11/19/2023 10:44:32 AM] Copying: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[11/19/2023 10:46:43 AM] Validating: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[11/19/2023 10:46:46 AM] Copied: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[11/19/2023 10:46:46 AM] Generating Autoinstall.lst
[11/19/2023 10:46:46 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
You are still using a cutdown map version…
So I’m going to ask a very simple and direct question: Is your unit NA with NAV from the factory?.
SIGN errors are not good, it means something is not working as it should.
So about the cut down map version; yes, I chose the Central NA map as I am in Oklahoma and just need that area and texas, etc…Do I need to download the whole NA map in order for this to work?
Your 2nd question, yes my unit is from Ford directly in NA with built in NAV, its never been replaced, and i purchased the vehicle brand new so no other owners. I originally installed the tool in order to just get the maps updated, but saw the Sync version update so I got that too. Everything was working prior, just with outdated maps.
Not really, you only need the proper file.
At this point, I would install all maps.
There’s really no reason to omit files since your unit can contain all the maps.
As @SaNdMaN indicated, you should install the entire NA map package via reformat. Since you will never be able to generate the needed license file from Ford for your vehicle. (Assuming this is for a 2017 Explorer.)
OK I’ll try that tonight, thanks!
Looks like that did the trick. I had to downgrade the Sync version and I loaded all NA maps, thanks for everyone’s help.
