Navigation malfuction
Hi, i have Ford Ranger 2020 from Turkey and i uptade syn3.4.22110 , f11 eu maps. I didn’t get any error while installing. ‘navigation malfuction’ give an error after restart. Thanks in advance.
SYNC Region: Europe
Navigation Variant: Yes
Old SYNC Version: 3.21194
New SYNC Version: 3.4.22110
Syn3 Updater Version: 2.11.3.3.0
VIN: 6FPPXXMJ2PLD15597
Version 5U5T-14G381-EZ
APIM Model: LU5T-14G371-HKC
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 7.0G
12.07.2022 16:44:03 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 1.0M / 1.1G
/fs/sd/MAP/ = 14M / 2.8G
/fs/sd/MAP/ = 14M / 2.3G
/fs/sd/MAP/ = 7.8M / 1.5G
/fs/sd/MAP/ = 21M / 3.8G
/fs/sd/MAP/ = 336K / 38M
/fs/sd/MAP/ = 25M / 3.2G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 751M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 17K / 496K
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 7.0G / 25G
Installed Packages
1U5T-14G424-BL
1U5T-14G658-AH
5U5T-14G391-AS
1U5T-14G421-BCJ
1U5T-14G421-BDJ
1U5T-14G421-BHJ
1U5T-14G421-BJJ
1U5T-14G421-BAJ
1U5T-14G421-BGJ
1U5T-14G421-BBJ
APIM AsBuilt
DE00: 0A6A018213022A4A40D0
DE01: 54550503C002080000800105
DE02: 0000040300
DE03: 01002F000D0008
DE04: 17FE17FE3185
DE05: 80
DE06: 160133000000001676000056568B0081
MASTER RESET as stated in the guide
I did it, but it is still not working.
The version number doesn’t appear near the navigation maps version like on the photo.
Is the car imported?
Your APIM is 32GB, EU maps need a 64GB one.
If it’s imported, you will need to change regions.
On the clock settings its writing: gps data unavailable.
APIM data
Post your log file, what you posted is not the log file
ACM
Please stop posting random stuff that’s not relevant, please post what has been requested.
You not being able to respond to some very basic and punctual questions tells a story…
US (NA) Rangers are 32GB, ROW are 16GB, and EU are 64GB. (NAV). I had an opportunity to have to look this up a while ago…so this could be an imported vehicle. But there are no remnants of the US maps and there is plenty of free space left on the unit. Looks like maybe an asbuilt or license issue?
There are no Nav Voice files installed and there is a GPS error. This would need to be corrected first.
CYANLABS - SYN3 UPDATER - V2.11.3.0
Version: 3.4.22110
Install Mode: Otomatik Tarama (autoinstall)
My20 Protection Enabled: Otomatik Tarama
; CyanLabs Syn3Updater 2.11.3.0 Stable - Autoinstall Mode - Sadece Harita Güncelleyin EU
[SYNCGen3.0_3.0.1_PRODUCT]
Item1 = MAP_LICENSE - 1U5T-14G424-BL_1646159765000.TAR.GZ
Open1 = SyncMyRide\1U5T-14G424-BL_1646159765000.TAR.GZ
Item2 = MAP - 1U5T-14G421-BAJ_1644010894000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G421-BAJ_1644010894000.TAR.GZ
[SYNCGen3.0_3.0.1]
Item1 = MAP - 1U5T-14G421-BGJ_1644011311000.TAR.GZ
Open1 = SyncMyRide\1U5T-14G421-BGJ_1644011311000.TAR.GZ
Item1 = VOICE_NAV - 4U5T-14G422-BDG_1644012081000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G422-BDG_1644012081000.TAR.GZ
Item2 = MAP - 1U5T-14G421-BBJ_1644008981000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G421-BBJ_1644008981000.TAR.GZ
FILES (5)
4U5T-14G422-BDG_1644012081000.TAR.GZ (2GB)
[11.07.2022 23:35:58] Selected Region: EU - Release: Sadece Harita Güncelleyin - Map Version: EU - 2022-07-11 - 1657571650
[11.07.2022 23:35:58] Install Mode: Otomatik Tarama (autoinstall) Forced: False
[11.07.2022 23:35:58] MY20 Protection: Otomatik Tarama
[11.07.2022 23:35:58] Formatting USB drive
[11.07.2022 23:35:58] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[11.07.2022 23:36:05] Checking Existing File: 1U5T-14G424-BL_1646159765000.TAR.GZ
[11.07.2022 23:36:05] Downloading: 1U5T-14G424-BL_1646159765000.TAR.GZ
[11.07.2022 23:36:06] Validating: 1U5T-14G424-BL_1646159765000.TAR.GZ
[11.07.2022 23:36:06] Downloaded: 1U5T-14G424-BL_1646159765000.TAR.GZ
[11.07.2022 23:36:06] Checking Existing File: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[11.07.2022 23:36:06] Downloading: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[11.07.2022 23:42:42] Validating: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[11.07.2022 23:42:47] Downloaded: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[11.07.2022 23:42:47] Checking Existing File: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[11.07.2022 23:42:47] Downloading: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[11.07.2022 23:43:59] Validating: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[11.07.2022 23:44:00] Downloaded: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[11.07.2022 23:44:00] Checking Existing File: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[11.07.2022 23:44:00] Downloading: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[11.07.2022 23:49:33] Validating: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[11.07.2022 23:49:37] Downloaded: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[11.07.2022 23:49:37] Checking Existing File: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[11.07.2022 23:49:37] Downloading: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[11.07.2022 23:54:33] Validating: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[11.07.2022 23:54:37] Downloaded: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[11.07.2022 23:54:37] Preparing USB drive
[11.07.2022 23:54:37] Checking Existing File: 1U5T-14G424-BL_1646159765000.TAR.GZ
[11.07.2022 23:54:37] Copying: 1U5T-14G424-BL_1646159765000.TAR.GZ
[11.07.2022 23:54:37] Validating: 1U5T-14G424-BL_1646159765000.TAR.GZ
[11.07.2022 23:54:37] Copied: 1U5T-14G424-BL_1646159765000.TAR.GZ
[11.07.2022 23:54:37] Checking Existing File: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[11.07.2022 23:54:37] Copying: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[11.07.2022 23:57:59] Validating: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[11.07.2022 23:58:22] Copied: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[11.07.2022 23:58:22] Checking Existing File: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[11.07.2022 23:58:22] Copying: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[11.07.2022 23:59:04] Validating: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[11.07.2022 23:59:09] Copied: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[11.07.2022 23:59:09] Checking Existing File: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[11.07.2022 23:59:09] Copying: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[12.07.2022 00:02:06] Validating: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[12.07.2022 00:02:26] Copied: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[12.07.2022 00:02:26] Checking Existing File: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[12.07.2022 00:02:26] Copying: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[12.07.2022 00:05:21] Validating: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[12.07.2022 00:05:42] Copied: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[12.07.2022 00:05:42] Generating Autoinstall.lst
[12.07.2022 00:05:42] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
You can’t change region with a autoinstall, but its unclear if you are trying to change region…
If you are trying to install maps for Turkey you have the wrong map package.
Yes, i am trying to install turkey maps. Which map package do I need to install?
The latest package for your region is:
4U5T-14G421-DAF 4.6Gb Sync3 v3.2.20339 TUR 2.20 (19.06.2020), ANZ.2.20 (19.06.2020), SA.2.20 (19.06.2020), TW.2.20 (19.06.2020)
4U5T-14G422-DG 1.5Gb Sync3 v3.2.20339 ANZ 901/20201116, SA 900-901/202007-11, TUR 900/20200824
4U5T-14G424-DAF License for 4U5T-14G421-DAF (ESN) EU.2.20 (19.06.2020) Tur, ANZ and etc.
However, the map license is ESN locked and requires downloading from FORD.
This is not available thru the Syn3 Updater…
Thank you for the answer.
