Dear Cyanlabs,
Navigation maps can used maps in Cambodia country ? my Ford f150 limited 2016 import from Canada, i really need your help
If you imported an NA car and you are now using it in another region you will need to change the region in the as built by using FORScan. Only after you change the region and install SYNC/maps with that region will you get this error to go away.
CyanLabs does not support changing region, however there are posts and other guides available elsewhere that can help you out.
thanks avdonr,
but do you know Ford have navigation maps in Cambodia country or not?
Not sure. You are probably ROW region so you can try that and see if it works.
