Navigation Map G10
Hello, everyone!
I have the 2022 model Ford Ranger. As far as I understand, these vehicles are coming to Turkey through Taiwan, so I updated the software from 3.4.21194 to 3.4.23188 using Cyanlabs Syn3 Updater. While doing this, I chose the option to preserve existing maps because my map version appears as G10, and I couldn’t find the current map that fits it in. I’d be glad if anyone who knows about the G10 map or knows how to update maps as a map of Europe, can help .
SYNC Region: ANZ
Old SYNC Version: 3.4.21194
Syn3 Updater Version: 2.13.00
Operating System: Microsoft Windows 11 Home Single Language (2009)
Version: 3.4.21194
Region: ANZ
Install Mode: Otomatik Tarama (autoinstall)
My20 Protection Enabled: Otomatik Tarama
Model: Generic STORAGE DEVICE USB Device
; CyanLabs Syn3Updater 2.13.0.0 Stable - Autoinstall Mode - Sync 3.4.23188 ANZ
Item2 = VOICE - 5U5T-14G391-DS_1660784642000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-DS_1660784642000.TAR.GZ
Item3 = GRACENOTES - 4U5T-14G423-DC_1615429585000.TAR.GZ
Open3 = SyncMyRide\4U5T-14G423-DC_1615429585000.TAR.GZ
FILES (4)
5U5T-14G391-DS_1660784642000.TAR.GZ (1GB)
[17.11.2024 14:13:15] Selected Region: ANZ - Release: Sync 3.4.23188 - Map Version: Mevcut Haritaları Koru
[17.11.2024 14:13:15] Install Mode: Otomatik Tarama (autoinstall) Forced: False
[17.11.2024 14:13:15] MY20 Protection: Otomatik Tarama
[17.11.2024 14:13:15] Formatting USB drive
[17.11.2024 14:13:15] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[17.11.2024 14:13:23] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[17.11.2024 14:13:23] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[17.11.2024 14:13:23] Checking Existing File: 5U5T-14G391-DS_1660784642000.TAR.GZ
[17.11.2024 14:13:26] Validated: 5U5T-14G391-DS_1660784642000.TAR.GZ (Skipping Download)
[17.11.2024 14:13:26] Checking Existing File: 4U5T-14G423-DC_1615429585000.TAR.GZ
[17.11.2024 14:13:27] Validate: 4U5T-14G423-DC_1615429585000.TAR.GZ (Failed!, Downloading)
[17.11.2024 14:13:27] Downloading: 4U5T-14G423-DC_1615429585000.TAR.GZ
[17.11.2024 14:14:37] Validating: 4U5T-14G423-DC_1615429585000.TAR.GZ
[17.11.2024 14:14:40] Downloaded: 4U5T-14G423-DC_1615429585000.TAR.GZ
[17.11.2024 14:14:40] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[17.11.2024 14:14:40] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[17.11.2024 14:15:47] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[17.11.2024 14:15:49] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[17.11.2024 14:15:49] Preparing USB drive
[17.11.2024 14:15:49] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[17.11.2024 14:15:49] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[17.11.2024 14:15:49] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[17.11.2024 14:15:49] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[17.11.2024 14:15:49] Checking Existing File: 5U5T-14G391-DS_1660784642000.TAR.GZ
[17.11.2024 14:15:49] Copying: 5U5T-14G391-DS_1660784642000.TAR.GZ
[17.11.2024 14:16:59] Validating: 5U5T-14G391-DS_1660784642000.TAR.GZ
[17.11.2024 14:17:02] Copied: 5U5T-14G391-DS_1660784642000.TAR.GZ
[17.11.2024 14:17:02] Checking Existing File: 4U5T-14G423-DC_1615429585000.TAR.GZ
[17.11.2024 14:17:02] Copying: 4U5T-14G423-DC_1615429585000.TAR.GZ
[17.11.2024 14:18:00] Validating: 4U5T-14G423-DC_1615429585000.TAR.GZ
[17.11.2024 14:18:03] Copied: 4U5T-14G423-DC_1615429585000.TAR.GZ
[17.11.2024 14:18:03] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[17.11.2024 14:18:03] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[17.11.2024 14:19:00] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[17.11.2024 14:19:03] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[17.11.2024 14:19:03] Generating Autoinstall.lst
[17.11.2024 14:19:03] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Hello.
I’ve not heard about G10 maps, so I’m not sure what you are talking about.
Can you run an interrogator log against the unit and share the resulting XML file?
Please do not post multiple consecutive messages, there’s an edit button for a reason… and personally speaking, bumping a thread makes me lose interest in the bumped thread…
Back to your problem, the interrogator was helpful, thank you.
You are trying to change regions, and Cyanlabs does not support changing regions.
Having said that, check out this thread for guidance → Tutorial: Current EU Maps Installation on US Imported Vehicles
Just be careful, you have a MY20 unit that can’t be reformatted with Syn3updater… Since the unit is quite full, you may want to check into FMODS’ universal reformat package, which can reformat MY20 hardware… The unit need to be jailbroken, which we do not support either.
Actually I do not want to change regions, the ANZ or EU version is irrelevant. I just want to update navigation map which is shown as G10, do we have any map with G code?
The map file, -BAL is the latest.
There is a later update for the nav voice file on you vehicle, -DH.
You can update this file using the Syn3 updater or Ford files thru the Sync Navigation update website.
Thank you for your answer. But as mentioned in the answer above before you I have reformatted my system to change EU system. Unfortunately my navigation system gives error and not working now. I have tried to update maps with only maps option but did not worked either.
You need to make sure that the system is set to the correct region and has the proper maps for that region. This is outlined in the tutorial posted above.
