Navigation not working after changing maps from US to MEA + NA
‘’‘’‘’‘’‘’‘’‘’‘’‘’‘’‘’'CYANLABS - SYN3 UPDATER - V2.11.9.0
Version: 3.4.21020
Model: SanDisk Ultra USB Device
[15/06/2023 07:49:15] Selected Region: ROW - Release: Sync 3.4.23088 - Map Version: 2021 Q4 - ROW (Middle East and North Africa)
[15/06/2023 07:49:15] Install Mode: Auto-Detect (downgrade) Forced: False
[15/06/2023 07:49:15] MY20 Protection: Disabled / Not MY20
[15/06/2023 07:49:15] Formatting USB drive
[15/06/2023 07:49:15] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[15/06/2023 07:49:24] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[15/06/2023 07:49:26] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[15/06/2023 07:49:26] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[15/06/2023 07:49:26] Validated: GB5T-14G386-SC_85041.tar.gz (Skipping Download)
[15/06/2023 07:49:26] Checking Existing File: 1u5t-14g386-cb.tar.gz
[15/06/2023 07:49:26] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[15/06/2023 07:49:26] Checking Existing File: 5U5T-14G391-FT_1660787787000.TAR.GZ
[15/06/2023 07:49:33] Validated: 5U5T-14G391-FT_1660787787000.TAR.GZ (Skipping Download)
[15/06/2023 07:49:33] Checking Existing File: 4U5T-14G423-FC_1615431949000.TAR.GZ
[15/06/2023 07:49:38] Validated: 4U5T-14G423-FC_1615431949000.TAR.GZ (Skipping Download)
[15/06/2023 07:49:38] Checking Existing File: NU5T-14G381-AC_1682460957000.TAR.GZ
[15/06/2023 07:49:42] Validated: NU5T-14G381-AC_1682460957000.TAR.GZ (Skipping Download)
[15/06/2023 07:49:42] Checking Existing File: Ford_MENA21Q4.tgz
[15/06/2023 07:49:46] Validated: Ford_MENA21Q4.tgz (Skipping Download)
[15/06/2023 07:49:57] Extracting: Ford_MENA21Q4.tgz (This may take some time!)
[15/06/2023 07:49:57] Added MultiPackage files to Queue
[15/06/2023 07:49:57] Preparing USB drive
[15/06/2023 07:49:58] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[15/06/2023 07:49:58] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[15/06/2023 07:50:38] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[15/06/2023 07:50:40] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[15/06/2023 07:50:41] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[15/06/2023 07:50:41] Copying: GB5T-14G386-SC_85041.tar.gz
[15/06/2023 07:50:41] Validating: GB5T-14G386-SC_85041.tar.gz
[15/06/2023 07:50:41] Copied: GB5T-14G386-SC_85041.tar.gz
[15/06/2023 07:50:41] Checking Existing File: 1u5t-14g386-cb.tar.gz
[15/06/2023 07:50:41] Copying: 1u5t-14g386-cb.tar.gz
[15/06/2023 07:50:41] Validating: 1u5t-14g386-cb.tar.gz
[15/06/2023 07:50:41] Copied: 1u5t-14g386-cb.tar.gz
[15/06/2023 07:50:41] Checking Existing File: 5U5T-14G391-FT_1660787787000.TAR.GZ
[15/06/2023 07:50:41] Copying: 5U5T-14G391-FT_1660787787000.TAR.GZ
[15/06/2023 07:51:36] Validating: 5U5T-14G391-FT_1660787787000.TAR.GZ
[15/06/2023 07:51:42] Copied: 5U5T-14G391-FT_1660787787000.TAR.GZ
[15/06/2023 07:51:42] Checking Existing File: 4U5T-14G423-FC_1615431949000.TAR.GZ
[15/06/2023 07:51:42] Copying: 4U5T-14G423-FC_1615431949000.TAR.GZ
[15/06/2023 07:52:53] Validating: 4U5T-14G423-FC_1615431949000.TAR.GZ
[15/06/2023 07:52:57] Copied: 4U5T-14G423-FC_1615431949000.TAR.GZ
[15/06/2023 07:52:57] Checking Existing File: NU5T-14G381-AC_1682460957000.TAR.GZ
[15/06/2023 07:52:57] Copying: NU5T-14G381-AC_1682460957000.TAR.GZ
[15/06/2023 07:54:02] Validating: NU5T-14G381-AC_1682460957000.TAR.GZ
[15/06/2023 07:54:06] Copied: NU5T-14G381-AC_1682460957000.TAR.GZ
[15/06/2023 07:54:06] Checking Existing File: 4U5T-14G421-FBK.tar.gz
[15/06/2023 07:54:06] Copying: 4U5T-14G421-FBK.tar.gz
[15/06/2023 07:54:58] Validating: 4U5T-14G421-FBK.tar.gz
[15/06/2023 07:55:01] Copied: 4U5T-14G421-FBK.tar.gz
[15/06/2023 07:55:01] Checking Existing File: 4U5T-14G424-FBK.tar.gz
[15/06/2023 07:55:01] Copying: 4U5T-14G424-FBK.tar.gz
[15/06/2023 07:55:01] Validating: 4U5T-14G424-FBK.tar.gz
[15/06/2023 07:55:01] Copied: 4U5T-14G424-FBK.tar.gz
[15/06/2023 07:55:01] Generating reformat.lst
[15/06/2023 07:55:01] Generating autoinstall.lst
[15/06/2023 07:55:01] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Now my truck is showing navigation error. I did the diagnostics but it does not show any satellite tracking data or time info. Please help. My country is Togo and I have followed the steps as per the guide and updated APIM and ACM characters as mentioned. Thanks a lot. ‘’‘’‘’‘’‘’‘’‘’‘’’
Below are the interrogator logs after the update:
VIN: 1FTE**********912
Version NU5T-14G381-AC
APIM Model: KU5T-14G371-CJA
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 20G
15/06/2023 12:55:27 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 384K / 764M
/fs/Nuance/ = 7.0M / 1.7G
/fs/Nuance/grace = 63M / 1.4G
/fs/rwdata/ = 1.0G / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 89M / 90M
/fs/mp/ = 84M / 1.4G
/fs/images/ = 20G / 25G
Installed Packages
4U5T-14G421-FBK
5U5T-14G391-FT
4U5T-14G423-FC
APIM AsBuilt
DE00: 2A2A000600042904048A
DE01: 544F0103C402429080004005
DE02: 0000010300
DE03: 000014030E0001
DE04: 1A681A6838A4
DE05: B0
DE06: 46003300000000029A000056569400C8
PS: I have tried installing twice and performed master reset each time. Still no luck!
Does everything else such as radio, music, phone etc. work as normal apart from navigation?
You had nav. before the update?
I think you edited the log beyond hiding your VIN
That package does not exist.
Besides, you are changing regions, which is not supported by cyanlabs and required modifications go the APIM’s configuration.
I’m sure you will be able to find information on the forums though, since there’s a tutorial that you will find relevant as reference (installing EU maps on a NA imported vehicle)
Hi @wiz043 yes the nav was working fine while i was driving in Canada. Also, when the truck got here, I could see the GPS data but obviously no maps. The surprising thing right now is that after the update, the data from the GPS sensor has stopped coming. Radio, music, phone is all working as it should.
Hi @SaNdMaN please see the below:
APIM Size: 32GB
Installed Packages
4U5T-14G421-FBK
5U5T-14G391-FT
4U5T-14G423-FC
APIM AsBuilt
DE02: 0000010300
DE04: 1A681A6838A4
DE05: B0
If anything else is needed, I can promptly provide that also. I have modified the APIM using FORScan and changed the country code from Canada to Togo (544F). Also modified the ACM. Kinda worried now why the GPS sensor has stopped outputting the data. Or why I have lost connection with it.
Below is the data from Interrogator after the update and I changed the country to Ghana (from Togo) to see if that makes a difference but no success:
VIN: 1FT00000000005912
APIM Size: 32GB
16/06/2023 15:32:58 +00:00
/fs/rwdata/ = 1021M / 1.2G
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/resources = 332K / 72M
Installed Packages
4U5T-14G421-FBK
5U5T-14G391-FT
4U5T-14G423-FC
1U5T-14G658-AH
APIM AsBuilt
DE00: 2A2A000600052904048A
DE01: 47480103C402429080004005
DE02: 0000010300
DE04: 1A681A6838A4
DE05: B0
It worked!!! I went for a different version of Sync which was Sync 3.4.21265. Now kinda afraid to go to the latest version or perform the software update. The version which was giving me issue was Sync 3.4.23088. Now my truck is in Togo and I have loaded ROW (ALL) maps and it works like a charm. Thanks for all the support received so far. I will be happy to help if someone faces similar issues.
Yep…apparently version 21265 is deemed one of the most stable if you want to go back to a previous version. :slightly_smiling_face:
Apologies for the delayed response. I do not think Sync3 version has something to do with it.
This can be easily tested: upgrade to a new Sync3 build while keeping maps, it’s a short process (10-15 minutes)… If other builds have issues, you can always go back to the one that works.
But it would be the first time I would see that navigation stops working because of Sync3 version.
The Sync version change via reformat wiped the RWdata folder and reset the map location data, etc…
Thanks very much for the explanation. I will update to the latest version and revert. Just wondering what will happen if I update my system using the automatic update from Ford?
To my knowledge once you update with Cyanlabs Ford no longer recognizes your vehicle for updates.
You probably should just disable automatic updates and wifi anyway and just use Cyanlabs for future updates. :wink:
Hello @jsingh172 i would like to do the same process as you did my car is ford escape 2020 NA but i would like to change the region and map from NA to Middle East (Iraq) i will appreciate that if you could assist me with that.
Thanks in advance
If you car is MY20 you can’t
@osamahaji I just followed the instructions step by step and they are actually nicely written. I would suggest to follow them thoroughly and if during any step you face difficulty then I will be happy to assist. And like mentioned above, firstly please check the version of your sync.
