Need a rundown what exactly jailbreak is
Hello I’m new to the ford jailbreaking, I’ve read on the cyan lab website that i am also able to jailbreak the modules abs etc to the latest version
Someone let me know what tool I need again for this?
Old SYNC Version: 3.1
No error messages for now
For Jailbraking the APIM you need to goto Fmods, not here. There is no way possible to JB other modules unless you work for ford and have access to the module passwords.
You can use Forscan to update calibrations and AB settings though but not Cyanlabs.
You can use Cyanlabs to update Maps and Sync software.
Ok yes I can use for scan and update calibration through WiFi or which usb cable to obd2?
Never use Wi-Fi for calibrations unless you want to risk bricking a module. For AB it’s quick enughf that the risk is minimal.
Also just becuse you can update a calibration does not mean you should.
Proven and instructed in the FORScan guide on their website.
Do you know if the download file is the latest update for updating the modules?
https://www.motorcraftservice.com/SetCountry?returnUrl=%2FHome%2FIndex
