Hello all, I just got a 2016 focus st and saw it was on 1.0. Used ford’s update and it didn’t add android auto and voice control is no linger working. Any ideas on how I can go from 3.0 to 2.2 to get android auto?
Ford have no idea what they are doing half the time, i have no idea if there incompatible hubs, SYNC 1.0 is before my experience with SYNC. i’m guessing the HUB could be the issue but i have no idea.
So, you got an official Ford update from 1.0 to 3.0 and Android Auto does not work, right?.
Usually CP (Car Play) is the one that need a compatible HUB in order to work, usually you could get away with Android Auto.
But since you may have an old USB HUB, one thing you could look into is purchasing a new usb HUB in order to discard if that’s the issue.
As I said before, I’m running 3.0 and Android Auto works like a charm, but it’s a 2017 model.
