No Audio from any speakers after sync 3 upgrade
Hi all!
So this is my issue , I upgraded from the sync 1 small little screen to sync 3 with the latest 3.4 … I have absolutely no sound from any speakers , I’ve done all the self diag tests in forscan , and on sync debug mode itself and still nothing.
A bit of back story , I’m gen 3 coyote swapping my ecoboost mustang , so I had to replace my dash harness , body harness , BCM and ecu etc etc , all my harness are BRAND NEW OEM from ford so I can confirm I’m not having a wiring issue.
I’m using a 2021 sync 3 system with apim NON Nav , my 2018 ecoboost ACM , and a 2019 DSP , all gen 3 stuff. I’m pretty fluent in for scan , and cannont for the LIFE of me figuring out as to why I have no sound from my speakers… fuses are all good , sync functions perfectly , no touch screen beeps or sound …
My ACM , APIM , and DSP module are all being found in forscan … I do however get 1 DTC code from the DSP module
Audio line enabled short to ground … all the connectors are properly seated , no broken pins or wires , and all my interior grounds are perfectly seated … I’m just lost at this point …and just as another bit of info I’m not using any jumper harnnnes or adapters
Old SYNC Version: 1.2
B13FB
Did you try a soft reset and factory reset?
Post the asbuilts for the APIM, ACM, and DSP.
Post the part numbers for each of those.
Which ones did you replace? which ones are OEM?
Yeaaaa……
