Hello,
i hope i got all the information right. Lately i wanted to update my SYNC3 the official way. After preparing everything i went for a little trip while keeping the pendrive in the usb port. A little banner on top said “system update processing …” or something like that. After 1.5h of driving I had to turn it off since i had to go.
I was prepared for max. 30 minutes, since Ford mentioned it that way. Next day i started the car again it said “update finished, update will be available after the next start”, but after the next start the display stayed black. Only the backlight went on. USB is not working, at least my phone is not charging. No radio, no bluetooth.
Does anyone has some hints how i can fix this misery? Can I give you more information ?
I’ve already found some similar posting here to this topic, but i can’t realy get a real solution out of this different posts.
I can read out some APIM information with forscan:
Part number: HS7T-14G371-FAD
Calibration level: HS7T-14G371-FAD
Harduare Number: HS7T-14G380-CA
Strategy (CAN, F188): GB5T-14G374-CB
Calibration (CAN, F124): GB5T-14G375-FA
ECU Configuratio/Sound: None
ECU Configurationuminaton None
Image (USB, 8033): HNIT-14G381-LF
Image (CAN Sub DO, 8033): None
Old SYNC Version: 2.2.16223
New SYNC Version: 2.2.16223
