No more GPS after update
Hello, my English is not the best. That’s why using google translator.
I want to do a map update to F.12. I got it from Ford. In part two I always get the error MEM_ERR03. But under settings it says that F12 is on it.
I’ve already done a soft reset and a master reset. But I haven’t had GPS since then. Can the problem be solved somehow?
Thanks.
Old SYNC Version: 3.4.21194
MEM_ERR03 – Error is MEM_NOSPACE_TO_EXTRACT
Hi.
This is what I would like you to provide.
  • the autoinstall.lst file Ford pushed your way
  • the . XML file generated by an interrogator log. You can create the tool with Syn3Updater, redact the VIN from the file’s name and content if you care about that (you can open it as a text file).
With that, I will be able to review what’s on the unit and if anything is missing.
I’m a bit loss as to why the nav does not work, since an incomplete upgrade should not do that…
Is the car imported?.
Hi Sandman and thank you. the car ist not importet.
XML:
Sync_NZ9P00MZ_WF0FXXGAHFLY52572.xml (11.1 KB)
VIN: WF0FXXGAHFLY52572
Version NU5T-14G381-AD
APIM Model: LU5T-14G371-GKF
APIM Typ: Navigation
APIM Größe: 64GB
APIM Freier Speicherplatz: 13G
05.02.2024 20:26:12 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 804K / 1.2G
/fs/sd/MAP/ = 15M / 2.9G
/fs/sd/MAP/ = 14M / 2.4G
/fs/sd/MAP/ = 7.6M / 1.5G
/fs/sd/MAP/ = 17M / 2.3G
/fs/sd/MAP/ = 21M / 3.8G
/fs/sd/MAP/ = 308K / 40M
/fs/sd/MAP/ = 4.5M / 3.3G
/fs/sd/MAP/ = 26M / 3.2G
/fs/Nuance/ = 28M / 4.8G
/fs/Nuance/ = 29M / 5.0G
/fs/Nuance/ = 26M / 4.4G
/fs/Nuance/ = 36M / 3.7G
/fs/Nuance/ = 940K / 244M
/fs/rwdata/ = 904M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 13G / 54G
Installed Packages
1U5T-14G421-BAK
1U5T-14G421-BBK
1U5T-14G421-BCK
1U5T-14G421-BDK
1U5T-14G421-BEK
1U5T-14G421-BFK
1U5T-14G421-BGK
1U5T-14G421-BHK
1U5T-14G421-BJK
1U5T-14G658-AH
1U5T-14G424-BM
4U5T-14G422-BAK
4U5T-14G422-BBK
5U5T-14G391-EM
4U5T-14G422-BCK
4U5T-14G422-BDK
APIM AsBuilt
DE00: 8A6A059A50027C0440C2
DE01: 474D0B0AC08A0890A8BC4E04
DE02: 0000010000
DE03: 00001D82310101
DE04: 190819082653
DE05: 80
DE06: 0B0533000000006428000056565F0061
Autoinstall from Ford:
; SYNC3 Consumer Application
Upgrade - Release 3.4.23188 - Only
for Nav/EU assemblies.
[SYNCGen3.0_3.4.23188_PRODUCT]
Item1 = HB5T-14G386-VCB
Open1 = SyncMyRide\HB5T-14G386-VCB.tar.gz
Item2 = HB5T-14G386-VHA
Open2 = SyncMyRide\HB5T-14G386-VHA.tar.gz
Item3 = 1U5T-14G424-BM
Open3 = SyncMyRide\1U5T-14G424-BM.tar.gz
Item4 = 1U5T-14G421-BAK
Open4 = SyncMyRide\1U5T-14G421-BAK.tar.gz
Item5 = 1U5T-14G421-BCK
Open5 = SyncMyRide\1U5T-14G421-BCK.tar.gz
Item6 = 1U5T-14G421-BDK
Open6 = SyncMyRide\1U5T-14G421-BDK.tar.gz
Item7 = 1U5T-14G421-BEK
Open7 = SyncMyRide\1U5T-14G421-BEK.tar.gz
Item8 = 1U5T-14G421-BFK
Open8 = SyncMyRide\1U5T-14G421-BFK.tar.gz
Item9 = 1U5T-14G421-BGK
Open9 = SyncMyRide\1U5T-14G421-BGK.tar.gz
Item10 = 1U5T-14G421-BHK
Open10 = SyncMyRide\1U5T-14G421-BHK.tar.gz
[SYNCGen3.0_3.4.23188]
Item3 = 1U5T-14G421-BJK
Open3 = SyncMyRide\1U5T-14G421-BJK.tar.gz
Item4 = 1U5T-14G421-BBK
Open4 = SyncMyRide\1U5T-14G421-BBK.tar.gz
Item5 = 4U5T-14G422-BAK
Open5 = SyncMyRide\4U5T-14G422-BAK.tar.gz
Item6 = 4U5T-14G422-BBK
Open6 = SyncMyRide\4U5T-14G422-BBK.tar.gz
Item7 = 4U5T-14G422-BCK
Open7 = SyncMyRide\4U5T-14G422-BCK.tar.gz
Item8 = 4U5T-14G422-BDK
Open8 = SyncMyRide\4U5T-14G422-BDK.tar.gz
Item1 = GB5T-14G386-AE
Open1 = SyncMyRide\GB5T-14G386-AE.tar.gz
Item2 = LU5T-14G386-CA
Open2 = SyncMyRide\LU5T-14G386-CA.tar.gz
Thanks.
I’m on mobile right now, but based on what I’m seeing, all relevant packages are currently installed on the unit.
That is 14G422-BxK and 14G421-BxK. Other packages are tools.
What is the issue you are currently having?.
Have you performed a master reset?.
I thank you for your time. I did a master reset. I’ve already disconnected the battery. maybe the antenna is defective. I don’t have GPS anymore. can no longer navigate.
Is the unit under warranty?.
Is the car stock?.
Try going into bezel diagnostics to see if the car see the satellites.
I will double check something else, but from the package perspective there’s no reason for your current issue.
EDIT: I’ve double checked that your configuration seems ok, at least at first glance.
Check bezel diagnostics to see if the car can see satellites.
That’s always a possibility. Is it stock?.
hi. the diagnosis says 1-7 satellites. but no glonass GPS satellite. Most of the time only 2 satellites are displayed. could be the antenna. Car still has warranty.
Hi Sandman. Yesterday I removed the Gracenote with cyanlabs. Suddenly GPS works again. But now the woman only speaks English to me. how do I get the language back to German? thank you for your time.
I’m not sure what’s going on, further more, I’m clueless as to why you decided to remove gracenotes.
The issues you are describing has nothing to do with each other. Did you wait some time after the initial upgrade for the car to get GPS lock?.
Reinstall gracenotes since it has nothing to do with the GPS thing.
About the voice, I would not know either, since packages pushed by Ford are correctly installed and are for EU as far as I saw. Check the configuration to see if there’s any specific setting. The UI is in German?.
hi. I’ll run the Ford update again or should I do the USB stick via cyanlabs? had removed Gracenote because I always had the mem err 03. Was that wrong. I haven’t had the GPS signal since December.
Hi Sandman. I reinstalled Gracenote and the navigation language is again in German. And GPS is back too. I have no idea how this all of a sudden works, but it works. Thank you for your patience.
That makes 2 of us: I have no idea what’s the relationship among those issues…
But hey, if it works, it works… :wink:
Close, but maybe created enough room for the temp map files to start? Run the RWData cleaner.
may be. I’m happy because it finally works again. Thanks again.
