No valid "ECU Delivery Assembly Number"
I just put in a new APIM with nav in my 18 MKX. It was a my20 model. It has version 3.4.22251 installed on it and its not holding any settings. (Like camera delay or the time) When I tried to use the updater I followed the steps and uploaded my Interrogator file and it came up with the error "The XML file you have selected does not contain a valid “ECU Delivery Assembly Number” I know it was manufactured 5/9/23. Is there a way I can update this still?
Install Type: OEM Replacement
Old SYNC Version: 3.4.22251
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2023-09-12" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>2LMPJ8JR2JBL17799</p:VIN>
<p:RequestRole>
</p:RequestRole>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>NU5T-14G381-AB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>345535542d3134473432312d434145000000000000000000345535542d3134473432312d434245000000000000000000345535542d3134473432312d434345000000000000000000345535542d3134473432312d434445000000000000000000345535542d3134473432312d434545000000000000000000345535542d3134473432312d434645000000000000000000345535542d3134473432312d434745000000000000000000345535542d3134473432312d434845000000000000000000345535542d3134473432312d434a45000000000000000000355535542d3134473339312d435300000000000000000000345535542d3134473432322d43414b000000000000000000345535542d3134473432322d43424b000000000000000000345535542d3134473432322d43434b000000000000000000345535542d3134473432332d434300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>00000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>2280001340020008008a</d2p1:Response>
</d2p1:DID>
<d2p1:Response>555300000000000028000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>0a000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-1U5T-14G371-EE</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>1U5T-14G375-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>W2587FK8</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>1U5T-14G374-EE</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>64:8c:bb:db:f9:c5</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2023-09-12T11:54:10+00:00" RAM="1015517184" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="12M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.4G" available="12M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.4G" available="10M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="951M" available="2.9M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="8.6M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.8G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.7G" available="17M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.4G" available="6.7M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.6G" available="15M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.1G" available="10M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="2.5G" available="24M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="465M" available="3.2M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="775M" available="5.8M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="960M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="84M"/>
<d2p1:PartitionHealth type="/fs/images/" total="25G" available="4.2G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
If you know it’s MY20 manually set the advanced settings to “my20”
DO NOT UNDER ANY CIRCUMSTANCES SET IT TO NOT MY 20 OR YOU WILL BRICK YOUR APIM.
You need to get out of that build, it does not really matter the APIM s not presenting itself , since you know it’s MY20.
Follow this guide → APIM Sync Settings Not Saving, VER_ERR08 Errors, Cannot Perform Master Reset or Upgrades/Updates
Of course, try running the rwdata cleaner first
Got it updated to 3.4.23188, Thanks! Is there a reason only 2020 maps were available for the MY20?
You can’t install locked maps without reformat, and since your APIM is MY20 you can’t reformat it…hence Syn3Updater is only giving you the option you can do without bricking your unit …
