I downloaded the Cyanlabs updater and followed all instructions, i.e. updated my current built and selected correct region, downloaded all files (3.4 excl maps) etc. BUT, unfortunately after I plug in my USB drive in my cars USB socket nothing happens. I tried the ‘official ford way’ as well, and I have the same issue. I understand some text should display at the top of the screen and some pop up windows should appear as well, but nothing. I waited for several minutes thinking maybe it was a bit slow, but no luck. I had engine on and then plugged the USB drive in - nothing. I switched the engine off, plugged USB drive in and then started the engine again - nothing. I can see my drive receives power from the USB port, Apple Carplay works fine too.
I am not sure what is going on. Any suggestions\advice?
