I converted my 2015 Ford Fusion SE from Sun 2 to Sync 3 about 6 or 7 years ago. Recently the APIM failed and I replaced it with one from a salvage yard. I thought I got it all working (copied APIM settings from a 2016 Ford Fusion), but Forscan has been throwing a bunch of errors.
===PCM DTC None===
Successful DTC reading, no error codes found
Module: Powertrain Control Module
===END PCM DTC None===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC U0151:00-08===
Code: U0151 - Lost Communication With Restraints Control Module
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
===END APIM DTC U0151:00-08===
===APIM DTC U0452:00-08===
Code: U0452 - Invalid Data Received From Restraints Control Module
Status:
===END APIM DTC U0452:00-08===
===APIM DTC U2101:00-0B===
Code: U2101 - Control Module Configuration Incompatible
Status:
- DTC Present at Time of Request
===END APIM DTC U2101:00-0B===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===BdyCM DTC None===
Module: Body Control Module
===END BdyCM DTC None===
===FCIM DTC B10B3:15-0A===
Code: B10B3 - Right Panel Air Discharge Temperature
Additional Fault Symptom:
- Circuit Short To Battery Or Open
Status:
Module: Front Controls Interface Module
===END FCIM DTC B10B3:15-0A===
===FCIM DTC B10B4:15-0A===
Code: B10B4 - Right Floor Air Discharge Temperature
Status:
===END FCIM DTC B10B4:15-0A===
===FCIM DTC B11E5:15-0A===
Code: B11E5 - Left HVAC Damper Position Sensor
Status:
===END FCIM DTC B11E5:15-0A===
===FCIM DTC B1A63:15-0A===
Code: B1A63 - Right Solar Sensor
Status:
===END FCIM DTC B1A63:15-0A===
===FCIM DTC B1A64:15-0A===
Code: B1A64 - Left Solar Sensor
Status:
===END FCIM DTC B1A64:15-0A===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===PDM DTC None===
Module: Passengers Door Control Unit
===END PDM DTC None===
===DDM DTC B1163:15-48===
Code: B1163 - Left Mirror Heater Output
Status:
- Test not complete
Module: Drivers Door Module
===END DDM DTC B1163:15-48===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PSCM DTC U0415:00-08===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module ‘A’
Status:
Module: Power Steering Control Module
Freeze Frame #1:
-STEER_FEEL: Comfort - Steering Personalization Status
-SW_ANGLE: 0.00 ° - Steering Wheel Angle
-ODOMETER: 171050.0 km - Total Distance
-ECU_POWER_SUPPLY: 12.6 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 51 °C - ECU Internal Temperature
-EPAS_MOTOR_CUR: 0.00 A - EPAS Motor Current
-VSS: 0.0 km/h - Vehicle Speed
===END PSCM DTC U0415:00-08===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===GPSM DTC None===
Module: Global Positioning System Module
===END GPSM DTC None===
Old SYNC Version: 1.0.15139
Version: 1.0.15139
Model: Lexar USB Flash Drive USB Device
FILES (5)
[5/4/2024 1:03:19 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[5/4/2024 1:03:19 PM] Install Mode: Auto-Detect (reformat) Forced: False
[5/4/2024 1:03:19 PM] MY20 Protection: Disabled / Not MY20
[5/4/2024 1:03:19 PM] Formatting USB drive
[5/4/2024 1:03:19 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[5/4/2024 1:03:29 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[5/4/2024 1:03:29 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[5/4/2024 1:03:29 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/4/2024 1:03:29 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[5/4/2024 1:03:29 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[5/4/2024 1:03:30 PM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[5/4/2024 1:03:30 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[5/4/2024 1:03:32 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[5/4/2024 1:03:32 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[5/4/2024 1:03:35 PM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[5/4/2024 1:03:35 PM] Preparing USB drive
[5/4/2024 1:03:35 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[5/4/2024 1:03:35 PM] Copying: 1u5t-14g386-cb.tar.gz
[5/4/2024 1:03:37 PM] Validating: 1u5t-14g386-cb.tar.gz
[5/4/2024 1:03:37 PM] Copied: 1u5t-14g386-cb.tar.gz
[5/4/2024 1:03:37 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/4/2024 1:03:37 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/4/2024 1:03:38 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/4/2024 1:03:38 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/4/2024 1:03:38 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[5/4/2024 1:03:38 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[5/4/2024 1:04:21 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[5/4/2024 1:04:37 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[5/4/2024 1:04:37 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[5/4/2024 1:04:37 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[5/4/2024 1:05:41 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[5/4/2024 1:05:57 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[5/4/2024 1:05:57 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[5/4/2024 1:05:57 PM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[5/4/2024 1:07:32 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[5/4/2024 1:07:57 PM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[5/4/2024 1:07:57 PM] Generating reformat.lst
[5/4/2024 1:07:57 PM] Generating autoinstall.lst
[5/4/2024 1:07:57 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Asbuilt_Sync2.ab (23.1 KB)
Copied from 2016 Ford Fusion.abt (349 Bytes)
