Ford Mondeo has installed sync3. How to realize the OPS radar display as shown in the figure below? Sync3 has been changed to display. Now the radar parameters need to be changed. Thank you very much.
If your vehicle has 12 sensors, then firstly enable that option in your asbuilt using forscan if you haven’t already. You will also need to enable flank guard as per my instructions here:
I’ve installed 12 sensors and can also use the auto-parking function normally. I want to enable side protection now. You mean I need to do this now by replacing X with 3 in 7D0-02-02: #X ##### #- ####, thank you very much for your answer.
The side flank does not appear until you move your car, try driving it
Probably needs a calibration update to your PAM module, details in my earlier link
Have you changed the asbuilt settings for the PAM module to enable flank guard with the 12 sensors enabled? (Firmware probably needs to be updated also, as @Louage indicates above.)
736-01-01 x*xx xxxx xx
Parking Assist Channels
0=0CH
3=3CH
4=4CH
6=6CH
7=7CH
8=8CH
9=9CH
A=10CH
B=11CH
C=12CH
736-03-01 x*xx xxxx xx
Side Park Aid (SPA) Flank Guard (FG) / Front Park Aid (FPA) / Rear Park Aid (RPA)
0=FG enabled, FPA enabled, RPA enabled
1=FG enabled, FPA enabled, RPA disabled
2=FG enabled, FPA disabled, RPA enabled
3=FG enabled, FPA disabled, RPA disabled
4=FG disabled, FPA enabled, RPA enabled
5=FG disabled, FPA enabled, RPA disabled
6=FG disabled, FPA disabled, RPA enabled
7=FG disabled, FPA disabled, RPA disabled
PAM As Built Database.xlsx (58.0 KB)
Looks like you might need a calibration update.
