Hey all,
I’ve read the documentation and the installation instructions, but I’m hoping someone can review my exported information to let me know if I have a low risk installation. My Ford Focus was built in 6/15 as 2016 model year. It has a low VIN for the model year (<100). It was owned by Ford corporate before me (purchased CPO) and I believe they had the head unit out of the vehicle before me. Reading some threads, it looks like some early Sync versions/hardware are higher risk.
I exported my vehicle data (below) and was hoping someone could review it and provide any warnings. If it’s high risk, I’ll leave my vehicle as is, and I’ve got CarPlay and don’t want to tempt fate. I have long ago replaced the USB Hub when CarPlay and AA were originally introduced for Sync 3.
I’m hoping this is the correct section in the forum. Thank you!
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2018-04-01" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>REDACTED</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>HN1T-14G381-SA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>484e31542d3134473339312d434300000000000000000000474235542d3134473432322d434a00000000000000000000484e31542d3134473432332d434100000000000000000000474235542d3134473432312d434a00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>00000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>546d369d</d2p1:Response>
</d2p1:DID>
<d2p1:Response>ab28640300029817000a</d2p1:Response>
</d2p1:DID>
<d2p1:Response>555301064082000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0002010000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01001301000001</d2p1:Response>
</d2p1:DID>
<d2p1:Response>17e8179828be</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>10043300000000135600000430670072</d2p1:Response>
</d2p1:DID>
<d2p1:DID didType="Direct Configuraation DID DE07" didValue="DE07">
</d2p1:DID>
<d2p1:DID didFormat="ASCII" didType="Private Sub Node #2 Software Number" didValue="F0E9" responseLength="24">
</d2p1:DID>
<d2p1:DID didFormat="ASCII" didType="ECU Cal-Config Part Number" didValue="F10A" responseLength="24">
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-AF</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GJ5T-14G380-BC</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GJ5T-14G371-CFB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
<d2p1:DID didFormat="ASCII" didType="Private Sub Node #3 Part Number" didValue="F12B" responseLength="24">
</d2p1:DID>
<d2p1:DID didFormat="ASCII" didType="Private Sub Node #4 Part Number" didValue="F12C" responseLength="24">
</d2p1:DID>
<d2p1:Response>VU2K1N26</d2p1:Response>
</d2p1:DID>
<d2p1:DID didFormat="ASCII" didType="Private Sub Node #2 Serial Number" didValue="F142" responseLength="16">
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:DID didFormat="ASCII" didType="ECU Cal-Config #2 Part Number" didValue="F16B" responseLength="24">
</d2p1:DID>
<d2p1:Response>GB5T-14G374-AF</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>d0:5f:b8:8d:e3:1e</d2p1:Response>
</d2p1:DID>
<d2p1:Response>d0:5f:b8:8d:e3:1f</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2018-04-01T21:26:18+00:00" RAM="1425453056" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/dev/hd0t180" total="7272847360" available="54710240"/>
<d2p1:PartitionHealth type="/dev/hd0t181" total="688572416" available="2097120"/>
<d2p1:PartitionHealth type="/dev/hd0t177" total="136764416" available="2097152"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Old SYNC Version: 2.2.17011
New SYNC Version: 3.4.22251
N/A (have not updated yet)
