“Error in 1st: NU5T-14G381-AB_1665525837000.TAR.GZ not found” Message displayed within first few seconds of trying to instal my update. my screen is now not letting me use any of my normal Sync 3 features (music, nav, phone etc. ) and I’m having trouble pushing the update through the rest of the way. I went through all of my files on my UBS 3.0 (64gb) thumb drive and that TAR.GZ file IS located on the thumb drive under the “syncmyride” folder. Any help would be greatly appreciated! My unit is stuck waiting on the update before I can use it now so the sooner I can get it fixed the better. vehicle is a 2017 Ford F-150 XLT FX4 with the 2.7L eco boost…
Old SYNC Version: 3.0
I had to change the “reformat.lst” file to text and share it that way because I’m on IOS and “.lst” is a windows file. Hope this helps you see where I’m stuck
What do you think?.
You are basically asking if naming is important in computer systems…
The process looks for files inside that folder, with that specific name.
So yes, that’s your issue.
Rename it and try again.
If something else happens and a file ins not found, make sure the files are correctly named as per the instructions, in both the directory as in reformat.lst
