I having intermittent startup (showing splash and then sometimes not) . I just recently did a SYNC 1 to SYNC 3 conversion. When able to boot I tried to master reset but it doesn’t erase anything. Then I tried the SYNC updater and getting a USB changed or remove, please reinsert. I changed USB and same result. Is this a faulty APIM and is there anyway to repair?
Old SYNC Version: 3.0
New SYNC Version: 3.0
USB changed or removed. Please reinsert
I don’t believe it to be a counterfeit. I bought it off marketplace that included the ACM,screen, and fascia from a focus. It has 3.0 currently…so looks like I took a hit then and need to replace it…smh. Also, could I use a 2020+ APIM in a sync 1 to sync 3 conversion?
Unfortunately I get this message when I plug any USB in…let alone having to turn on/off car multiple times to get my sync to start up…looks like I’m dead in the water….
“ Installation paused
The USB storage device has been changed or removed. Installation will resume when the device is re-inserted.”
Just an update. I was able to purchase another APIM (2019) on Ebay. Everything loaded correctly and working. I just need to update from 3.3 to 3.4. Thanks.
I got a newer APIM for $100. Your service was for $150. What exactly do you do to recover the APIM? I believe it’s corrupt. It wouldnt save anything and couldn’t master reset.
Getting a newer APIM for $100 is quite the deal, good for you. The fix for the APIM’s is no secret, can be found on the internet, but the expertise that @SFRANCO offers is not common. You need specific software and equipment to do this, or you brick it permanently.
