LEEJUNE
(LEEJUNE)
July 8, 2024, 6:53am
1
Should the Ford KUGA transmission range be selected as PRNDL or PRNDS in the IPC module?
Originally PRNDL.
SYNC Region: CN
Install Type: Replica
Old SYNC Version: 3.3.19052
MO
That would depend on the year and the vehicle spec which you seem to have kept secret.
If it was PRNDL originally and that matched the lettering on the Gear selector lever then i’d expect the display to match.
Have you made any changes?
LEEJUNE
(LEEJUNE)
July 10, 2024, 12:58am
3
First of all, thank you for your reply.
My car was produced in 2013. The identification on the gear lever is PRNDS. The dashboard display is also PRNDS, while the original factory data in IPC is PRNDL, so I would like to know if it is possible to modify it to PRNDS
Ps. Previously upgraded to IPC.
system
(system)
Closed
August 9, 2024, 12:59am
4
