Problem updating my new Ford Fiesta 2018
Hello everyone, first of all, thanks for helping so many people who are new to our cars, I really appreciate it.
I recently bought a 2018 ford Fiesta to replace my old 1999 Ford Mondeo, One of the things I saw is that the radio was not up to date nor did I have the maps activated, I activated the navigation through Fordscan, but I can not get an update to be installed not the maps. I currently have 3.3.19052 installed. I hope you can give me a cable because I do not understand very well what is failing. Greetings and thank you
SYNC Region: Europe
Navigation Variant: Yes
Old SYNC Version: 3.3.19052
New SYNC Version: 3.3.19052
Eroor with package EP-XXX
VIN: WF0JXXGAHJJT59593
Versión 4U5T-14G381-AN
Modelo de APIM: JK2T-14G371-ACC
Tipo de APIM: Non-Navigation
Tamaño de APIM: 16GB
Espacio libre en APIM: 6.9G
15/01/2014 12:54:15 AM +00:00
Partition Type = Free / Total
/fs/Nuance/ = 91M / 1.9G
/fs/Nuance/grace = 59M / 1.0G
/fs/rwdata/ = 905M / 1.2G
/fs/mp/ = 505M / 1.4G
/fs/mp/resources = 260K / 91M
/fs/images/ = 6.9G / 10G
Installed Packages
4U5T-14G391-AJ
4U5T-14G423-AA
1U5T-14G658-AD
APIM AsBuilt
DE00: 086A048210049C044080
DE01: 53500C01C08A088028B80005
DE02: 0000010004
DE03: 00001DE1010001
DE04: 190819082653
DE05: 40
DE06: 0B0533000000006428000056565D0061
Firstly, please edit your profile and add information about your vehicle.
About the log you provided: it shows it’s a 16GB APIM NO-NAV, so there’s your issue.
If you are EU based, you will need to have a 64 GB NAV-APIM (ideally).
You could get away with a 32GB one, but would have to install cut down maps.
I have tried to do it and it gives me this error, I have created a usb without nag and it gives me that error when trying to update
If the NAV was not activated, then you cannot just activate it and expect it to work. You do not have a NAV equipped APIM with the proper daughter board. This will not work…
As far as the pic above:
PKG_ERR03 – Error is PKG_UNTAR_FAILURE
This is usually due to a bad USB stick or not enough storage space on the APIM to process the files.
Post your installation log, please.
