Problems with update, error and red screen
hello cyanlabs I have problems with the update of sync 3 I have a ford focus se 2017 and I had a version of sync 3 2.2 16280 and I try to update to version 3.4.21194 but unfortunately when it reaches a certain percentage the screen turns red and an error appears , check all the data but I can’t find the problem
Navigation Variant: No
Old SYNC Version: 2.2.16280
New SYNC Version: 3.4.21194
error in 4U5T-14G421-DAF_1615429515000.TAR.GZ :
Syn3 Updater Version: 2.2.16280
https://cyanlabs.net/fhub/syn3-updater-log/?uuid=1ece01dd-1fea-675a-8d94-0242ac120002
Do you really have maps?
Do you have an image of the error?
Have you tried another USB?, maybe a quality branded one.
THE VERSION THAT I HAVE DID NOT HAVE MAPS, I ATTACHED THE IMAGE OF THE ERROR AND I ALSO THOUGHT OF GETTING A BETTER QUALITY USB WHICH I THINK MAY BE THE CAUSE OF THE PROBLEM. THANKS A LOT
Then you can not fit maps, you do not have enough STORAGE SPACE
I ALSO TRIED BUT THERE WAS A DIFFERENT ERROR, I THINK IT IS THE ONE I ATTACHED NOW, MAYBE YOU SEE THE BEST THING IS TO CHANGE THE USB.
THANKS FOR ANSWERING
Remove gracenotes, you don’t have enough space on your APIM to fit Non Nav with Gracenotes
Yep, you have a small APIM and these latest versions have more information than before. Removing GN will work.
THANK YOU VERY MUCH, I’LL TRY THAT AND REPORT HOW IT GOES, I SHOULD CHANGE USB OR WITH GN IT WOULD BE ENOUGH
THANK YOU VERY MUCH, I WILL TRY THAT AND REPORT HOW IT GOES
SHOULD IT STAY LIKE THIS? THANK YOU
yes
