Radio FM Autoset Can't Refresh
What is your SYNC Region?
CN
3.4 20192
Do you have Navigation?
YES
HELP
Radio FM Autoset Can’t Refresh
Have you master reset?
Pretty sure this isn’t related to your APIM but rather your ACM
Thx I will check the ACM, but no idea
There is a feature in the APIM called ‘Autostore Presets’ that is probably misconfigured.
7D0-02-02 xxxx xx*x xxxx
Autostore (Mixed Mode Presets Turns Off Autostore), Electronic Horizon Type, ICP (EFP) Type, ICP (EFP) Branding
0=Autostore Enabled, EH: MPP + Stubs, ICP (EFP) Type: EFP, ICP(EFP) Brand: Non-Branded
1=Autostore Enabled, EH: MPP + Stubs, ICP (EFP) Type: EFP, ICP(EFP) Brand: Branded
2=Autostore Enabled, EH: MPP + Stubs, ICP (EFP) Type: ICP, ICP(EFP) Brand: Non-Branded
3=Autostore Enabled, EH: MPP + Stubs, ICP (EFP) Type: ICP, ICP(EFP) Brand: Branded
4=Autostore Enabled, EH: MPP + Stub+Exp, ICP (EFP) Type: EFP, ICP(EFP) Brand: Non-Branded
5=Autostore Enabled, EH: MPP + Stub+Exp, ICP (EFP) Type: EFP, ICP(EFP) Brand: Branded
6=Autostore Enabled, EH: MPP + Stub+Exp, ICP (EFP) Type: ICP, ICP(EFP) Brand: Non-Branded
7=Autostore Enabled, EH: MPP + Stub+Exp, ICP (EFP) Type: ICP, ICP(EFP) Brand: Branded
8=Autostore Disabled, EH: MPP + Stubs, ICP (EFP) Type: EFP, ICP(EFP) Brand: Non-Branded
9=Autostore Disabled, EH: MPP + Stubs, ICP (EFP) Type: EFP, ICP(EFP) Brand: Branded
A=Autostore Disabled, EH: MPP + Stubs, ICP (EFP) Type: ICP, ICP(EFP) Brand: Non-Branded
B=Autostore Disabled, EH: MPP + Stubs, ICP (EFP) Type: ICP, ICP(EFP) Brand: Branded
C=Autostore Disabled, EH: MPP + Stub+Exp, ICP (EFP) Type: EFP, ICP(EFP) Brand: Non-Branded
D=Autostore Disabled, EH: MPP + Stub+Exp, ICP (EFP) Type: EFP, ICP(EFP) Brand: Branded
E=Autostore Disabled, EH: MPP + Stub+Exp, ICP (EFP) Type: ICP, ICP(EFP) Brand: Non-Branded
F=Autostore Disabled, EH: MPP + Stub+Exp, ICP (EFP) Type: ICP, ICP(EFP) Brand: Branded
If you have an ‘8’ then set to ‘0’. (Subtract 8 from you setting.)
THX But mine is 7D0-02-02 xxxx xx2x xxxx by defult
I think cause ACM “Mix Mode Presets” Enabled when I change to disabled it works
That is correct. The wording is deceiving in the Ford descriptions, it looks backwards.
