Radio will not upgrade, Getting XML File you have selected does not contain a valid ECU Delivery Assembly Number"
I upgrade my raio to build 22251 a few years ago and everything has been working fine until just a few weeks ago. All the sudden I kept getting a prompt to enable auto updates. No matter what i do, this keeps coming up. So thought I would just update it the the latest CynLabs version. Had no issues 3 year ago, but now I am getting subject error message. Plus, I’ve tried factory resetting the radio, that didn’t seemt to help either. Any suggestions would be appreciated.
Old SYNC Version: 3.4.22251
Please share the XML file produced by the interrogator log. You need to get out of that build, read APIM Sync Settings Not Saving, VER_ERR08 Errors, Cannot Perform Master Reset or Upgrades/Updates (Solved) for guidance.
Well shoot. I deleted it, as I was going to try and the upgrade again. I did look at the other post you linked in here, I’ll try that as well and let you know how it goes.
No problem, I just wanted to confirm the RWDATA partition’s size, which should be full. Try again and running the rwdata cleaner utility, it’s all documented on the other guide.
