Done the update from 3.3 to 3.4 all working fine apart from rear camera . It’s was nice and crisp before an in colour now its black and white and grainy . Thanks in advance
Guessing this is a aftermarket camera?
(Sorry for multiple edits phone kept copying the wrong link for some reason)
cheers i will give it a try and get back to you . yes its aftermarket camera
hi i tried the downgrade to lower version all i get now is please install usb drive .cheers
Please, provide the log for the USB you created and a picture of the error.
log-2022-05-22-15-56-38.txt (13.0 KB)
sorry dont know iff this helps
And the picture?
You are trying to reinstall everything, a full reformat with maps.
That’s not necessary, since you only need to downgrade Sync3 version.
Having said this, it should work.
Please provide a picture, and also make sure no other USB is connected
Ok, make sure no other USB is present or connected.
nothing apart from the usb stick.cheers
Ok, if no other device is connected (USB, SD card reader) and none of the USB ports trigger the update, I would suggest trying a different USB pendrive (not disk).
For some reason it’s not detecting the USB.
ok great i wiill get back to you (mite be while lol)
thanks for your quick replys
No problem!.
If you haven’t done so, try another USB port on the car (if you have more than one, maybe under the arm rest).
It’s a bit odd the issue you are having, since I assume you used this pendrive before (but maybe not a reformat process). The unit is 100% recoverable, it’s in the reformat phase, it just needs a reformat USB.
Just to rule something out, could you please post a screenshot of the USB’s root contents?.
Just to double check there’s a reformat.lst file on the root, with some text in it.
Am just on with creating a new usb .i will post a log of the usb when its comp0lete .cheers
CYANLABS - SYN3 UPDATER - V2.10.11.0
Version: 3.4.22048
Model: SanDisk Cruzer Glide 3.0 USB Device
VOICE=5U5T-14G391-AR_1633363332000.TAR.GZ
APPS=5U5T-14G381-EV_1644243443000.TAR.GZ
; CyanLabs Syn3Updater 2.10.11.0 Stable - downgrade Mode - Sync 3.4.22020 EU
FILES (21)
1U5T-14G658-AG_1626915602000.TAR.GZ (56.8MB)
5U5T-14G391-AR_1633363332000.TAR.GZ (1.5GB)
5U5T-14G381-EV_1644243443000.TAR.GZ (868.2MB)
1U5T-14G421-BBH_1615430406000.TAR.GZ (473.7MB)
1U5T-14G421-BJH_1615431074000.TAR.GZ (23.9MB)
1U5T-14G421-BHH_1615430859000.TAR.GZ (2.6GB)
1U5T-14G421-BFH_1615432204000.TAR.GZ (2.4GB)
1U5T-14G421-BEH_1615430614000.TAR.GZ (1.6GB)
1U5T-14G421-BDH_1615430533000.TAR.GZ (1.1GB)
1U5T-14G421-BCH_1615430471000.TAR.GZ (1.7GB)
1U5T-14G421-BAH_1615430310000.TAR.GZ (2.2GB)
1U5T-14G424-BK_1616682400000.TAR.GZ (1.7KB)
4U5T-14G422-BCF_1615431448000.TAR.GZ (1.6GB)
4U5T-14G422-BBF_1615431222000.TAR.GZ (2.2GB)
4U5T-14G422-BAF_1615431156000.TAR.GZ (2.3GB)
[22/05/2022 19:45:46] Selected Region: EU - Release: Sync 3.4.22020 - Map Version: F10 (2020) - EU (03 2021)
[22/05/2022 19:45:46] Install Mode: Auto-Detect (downgrade) Forced: False
[22/05/2022 19:45:46] MY20 Protection: Auto-Detect
[22/05/2022 19:45:46] Formatting USB drive
[22/05/2022 19:45:46] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[22/05/2022 19:45:58] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[22/05/2022 19:46:05] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[22/05/2022 19:46:05] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[22/05/2022 19:46:05] Validated: GB5T-14G386-SC_85041.tar.gz (Skipping Download)
[22/05/2022 19:46:05] Checking Existing File: 1u5t-14g386-cb.tar.gz
[22/05/2022 19:46:05] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[22/05/2022 19:46:05] Checking Existing File: 1U5T-14G658-AG_1626915602000.TAR.GZ
[22/05/2022 19:46:06] Validated: 1U5T-14G658-AG_1626915602000.TAR.GZ (Skipping Download)
[22/05/2022 19:46:06] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[22/05/2022 19:46:15] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[22/05/2022 19:46:15] Checking Existing File: 5U5T-14G391-AR_1633363332000.TAR.GZ
[22/05/2022 19:46:35] Validated: 5U5T-14G391-AR_1633363332000.TAR.GZ (Skipping Download)
[22/05/2022 19:46:35] Checking Existing File: 5U5T-14G381-EV_1644243443000.TAR.GZ
[22/05/2022 19:46:47] Validated: 5U5T-14G381-EV_1644243443000.TAR.GZ (Skipping Download)
[22/05/2022 19:46:47] Checking Existing File: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[22/05/2022 19:47:15] Validated: 1U5T-14G421-BGH_1615430797000.TAR.GZ (Skipping Download)
[22/05/2022 19:47:15] Checking Existing File: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[22/05/2022 19:47:24] Validated: 1U5T-14G421-BBH_1615430406000.TAR.GZ (Skipping Download)
[22/05/2022 19:47:24] Checking Existing File: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[22/05/2022 19:47:24] Validated: 1U5T-14G421-BJH_1615431074000.TAR.GZ (Skipping Download)
[22/05/2022 19:47:24] Checking Existing File: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[22/05/2022 19:47:59] Validated: 1U5T-14G421-BHH_1615430859000.TAR.GZ (Skipping Download)
[22/05/2022 19:47:59] Checking Existing File: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[22/05/2022 19:48:30] Validated: 1U5T-14G421-BFH_1615432204000.TAR.GZ (Skipping Download)
[22/05/2022 19:48:30] Checking Existing File: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[22/05/2022 19:48:51] Validated: 1U5T-14G421-BEH_1615430614000.TAR.GZ (Skipping Download)
[22/05/2022 19:48:51] Checking Existing File: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[22/05/2022 19:49:05] Validated: 1U5T-14G421-BDH_1615430533000.TAR.GZ (Skipping Download)
[22/05/2022 19:49:05] Checking Existing File: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[22/05/2022 19:49:25] Validated: 1U5T-14G421-BCH_1615430471000.TAR.GZ (Skipping Download)
[22/05/2022 19:49:25] Checking Existing File: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[22/05/2022 19:49:52] Validated: 1U5T-14G421-BAH_1615430310000.TAR.GZ (Skipping Download)
[22/05/2022 19:49:52] Checking Existing File: 1U5T-14G424-BK_1616682400000.TAR.GZ
[22/05/2022 19:49:52] Validated: 1U5T-14G424-BK_1616682400000.TAR.GZ (Skipping Download)
[22/05/2022 19:49:52] Checking Existing File: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[22/05/2022 19:50:24] Validated: 4U5T-14G422-BDF_1615431510000.TAR.GZ (Skipping Download)
[22/05/2022 19:50:24] Checking Existing File: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[22/05/2022 19:50:46] Validated: 4U5T-14G422-BCF_1615431448000.TAR.GZ (Skipping Download)
[22/05/2022 19:50:46] Checking Existing File: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[22/05/2022 19:51:14] Validated: 4U5T-14G422-BBF_1615431222000.TAR.GZ (Skipping Download)
[22/05/2022 19:51:14] Checking Existing File: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[22/05/2022 19:51:42] Validated: 4U5T-14G422-BAF_1615431156000.TAR.GZ (Skipping Download)
[22/05/2022 19:51:42] Preparing USB drive
[22/05/2022 19:51:42] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[22/05/2022 19:51:42] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[22/05/2022 19:52:29] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[22/05/2022 19:52:34] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[22/05/2022 19:52:34] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[22/05/2022 19:52:34] Copying: GB5T-14G386-SC_85041.tar.gz
[22/05/2022 19:52:34] Validating: GB5T-14G386-SC_85041.tar.gz
[22/05/2022 19:52:34] Copied: GB5T-14G386-SC_85041.tar.gz
[22/05/2022 19:52:35] Checking Existing File: 1u5t-14g386-cb.tar.gz
[22/05/2022 19:52:35] Copying: 1u5t-14g386-cb.tar.gz
[22/05/2022 19:52:36] Validating: 1u5t-14g386-cb.tar.gz
[22/05/2022 19:52:37] Copied: 1u5t-14g386-cb.tar.gz
[22/05/2022 19:52:37] Checking Existing File: 1U5T-14G658-AG_1626915602000.TAR.GZ
[22/05/2022 19:52:37] Copying: 1U5T-14G658-AG_1626915602000.TAR.GZ
[22/05/2022 19:52:42] Validating: 1U5T-14G658-AG_1626915602000.TAR.GZ
[22/05/2022 19:52:43] Copied: 1U5T-14G658-AG_1626915602000.TAR.GZ
[22/05/2022 19:52:44] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[22/05/2022 19:52:44] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[22/05/2022 19:53:59] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[22/05/2022 19:54:09] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[22/05/2022 19:54:09] Checking Existing File: 5U5T-14G391-AR_1633363332000.TAR.GZ
[22/05/2022 19:54:09] Copying: 5U5T-14G391-AR_1633363332000.TAR.GZ
[22/05/2022 19:56:37] Validating: 5U5T-14G391-AR_1633363332000.TAR.GZ
[22/05/2022 19:56:56] Copied: 5U5T-14G391-AR_1633363332000.TAR.GZ
[22/05/2022 19:56:56] Checking Existing File: 5U5T-14G381-EV_1644243443000.TAR.GZ
[22/05/2022 19:56:56] Copying: 5U5T-14G381-EV_1644243443000.TAR.GZ
[22/05/2022 19:58:15] Validating: 5U5T-14G381-EV_1644243443000.TAR.GZ
[22/05/2022 19:58:25] Copied: 5U5T-14G381-EV_1644243443000.TAR.GZ
[22/05/2022 19:58:25] Checking Existing File: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[22/05/2022 19:58:25] Copying: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[22/05/2022 20:01:32] Validating: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[22/05/2022 20:01:55] Copied: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[22/05/2022 20:01:55] Checking Existing File: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[22/05/2022 20:01:55] Copying: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[22/05/2022 20:02:38] Validating: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[22/05/2022 20:02:43] Copied: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[22/05/2022 20:02:43] Checking Existing File: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[22/05/2022 20:02:43] Copying: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[22/05/2022 20:02:46] Validating: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[22/05/2022 20:02:46] Copied: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[22/05/2022 20:02:46] Checking Existing File: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[22/05/2022 20:02:46] Copying: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[22/05/2022 20:06:55] Validating: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[22/05/2022 20:07:24] Copied: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[22/05/2022 20:07:24] Checking Existing File: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[22/05/2022 20:07:24] Copying: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[22/05/2022 20:11:12] Validating: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[22/05/2022 20:11:39] Copied: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[22/05/2022 20:11:39] Checking Existing File: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[22/05/2022 20:11:39] Copying: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[22/05/2022 20:14:14] Validating: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[22/05/2022 20:14:33] Copied: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[22/05/2022 20:14:33] Checking Existing File: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[22/05/2022 20:14:33] Copying: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[22/05/2022 20:16:14] Validating: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[22/05/2022 20:16:26] Copied: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[22/05/2022 20:16:26] Checking Existing File: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[22/05/2022 20:16:26] Copying: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[22/05/2022 20:19:03] Validating: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[22/05/2022 20:19:23] Copied: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[22/05/2022 20:19:23] Checking Existing File: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[22/05/2022 20:19:23] Copying: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[22/05/2022 20:22:54] Validating: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[22/05/2022 20:23:19] Copied: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[22/05/2022 20:23:19] Checking Existing File: 1U5T-14G424-BK_1616682400000.TAR.GZ
[22/05/2022 20:23:19] Copying: 1U5T-14G424-BK_1616682400000.TAR.GZ
[22/05/2022 20:23:19] Validating: 1U5T-14G424-BK_1616682400000.TAR.GZ
[22/05/2022 20:23:19] Copied: 1U5T-14G424-BK_1616682400000.TAR.GZ
[22/05/2022 20:23:19] Checking Existing File: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[22/05/2022 20:23:19] Copying: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[22/05/2022 20:26:26] Validating: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[22/05/2022 20:26:48] Copied: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[22/05/2022 20:26:48] Checking Existing File: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[22/05/2022 20:26:48] Copying: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[22/05/2022 20:29:22] Validating: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[22/05/2022 20:29:41] Copied: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[22/05/2022 20:29:41] Checking Existing File: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[22/05/2022 20:29:41] Copying: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[22/05/2022 20:33:07] Validating: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[22/05/2022 20:33:32] Copied: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[22/05/2022 20:33:32] Checking Existing File: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[22/05/2022 20:33:32] Copying: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[22/05/2022 20:37:10] Validating: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[22/05/2022 20:37:35] Copied: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[22/05/2022 20:37:36] Generating reformat.lst
[22/05/2022 20:37:36] Generating autoinstall.lst
[22/05/2022 20:37:36] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY
Yep, that looks good.
just on with the install in the van all going well at the moment
. thanks again for your help and assistance
That’s good. If you got past the previous “error” and the USB is doing its thing, its just a matter of time.
For some reason the other USB drive had issues.
Since it’s an EU installation, it will take well over 30 minutes but less than an hour.
So just be patient, it will be fine.
exracing map package takes a while ![]()
