Receiving an error when opening the syn3 updater/
Once the syn3 updater opens I receive an error box simply saying Error Not Found. When I click OK. it disappears but returns when I search for the USB drive.
Navigation Variant: Yes
Old SYNC Version: 3.0.20204
New SYNC Version: same
Error Not Found when syn3 updater opens
Syn3 Updater Version: 2.10.6.0 (stabele)
none
Comcast?
Actually your issue seems different, but may still be related
Our internet is through specrtum
I can see you are using a profile, have you tried a new profile?
Yes, I’ve tried different profiles. I’ve tried different USB drives. I just paired my phone to my computer to use a different internet connection. Same result. I’m sure it something simple that I’m screwing up.
Try deleting your configuration data completely and starting over, C:\ProgramData\CyanLabs and C:\Users\Blah\AppData\Local\CyanLabs
Deleted and reinstalled. Same thing is happening
Reinstalling Syn3 Updater won’t remove the data from those locations though… did you delete the data from those? if so send a screenshot
I have deleted the files. I didn’t find any files in the User folder. Would they be somewhere else?
Not sure why you are in a “Default.migrated” folder, you need to go to your user directory C:\users\username\AppData\Local
finally found it. It’s been deleted.
ok, and does it still do it?
After reinstalling this is what I get when the App opens.
Update: tried a different computer and it looks like everything is working as it should. Thanks for the help trying figure it out.
