Red screen :(
Hi. Ford Fusion 2019my imported from USA to Poland and I used the automatic method. It downgrade from 3.4 version, started installing files and after about 30 minutes a red screen with the text “error in 4u5t-14g422-bak_1682464728000.tar.gz:”
What to do?
Old SYNC Version: 3.4.23188
error in 4u5t-14g422-bak_1682464728000.tar.gz :
Syn3 Updater Version: Latest i download 2 days ago
I dont have it now, im in the car without pc
Possibility #1 is that you simply have a corrupted file or bad block on the USB stick
Possibility #2 is that since the NA NAV APIMs only have 32GB of space there’s not enough space to load the maps (EU units have 64GB). In which case you may need to use the cut down map installer.
How can i cut maps?
I try second time (the same files on usb) from begin and i saw error arrive when “extracting voice nav package”
Thank you
I need to try
Tutorial: Current EU Maps Installation on US Imported Vehicles - Ford / Guides - CyanLabs Official Community
I don’t know if it’s due to the even more cropped map or the reformat (both options combined at once), but the most important thing is that it worked and it works great! =) thank you thank you very much
Best regards from PL / Przemyśl :wink:
