ROW maps on NA Issue
What is your SYNC Region? NA
Do you have Navigation? Yes
What region is your SYNC APIM? ROW
What was your old SYNC Version? 1.1
What is your new SYNC Version? 3.4
Do you have a error message, if so what is it? Navigation Fault, Navigation is not functioning properly
How did you update, Ford Website / CyanLabs Website / Syn3 Updater? Syn3 Updater
  • What version of Syn3 Updater did you use? 2.10.6.0
  • Have you read the documentation at Syn3 Updater - CyanLabs ? Yes
  • Please paste your log output or provide the URL to your log file below
    (Log files can be found on the root of your USB drive or in [log-2021-10-20-16-49-13.txt|attachment](upload://dllsVLuHhVbwQemOwVeyGXTpFul.txt) (5.6 KB) )
Please provide any further details below
Hei,
I followed the tutorial in the link below to replace the NA maps with ROW maps.
  • The update progress went smooth without any issues. However, once the installation was complete and the APIM has rebooted I found yellow triangle sign ā€œHazard warningā€ in the Navi section in the screen home page, followed by a message ā€œNavigation Fault, Navigation is not functioning properlyā€ and then a popup message with ā€œNavigation Fault, please contact the nearest Ford dealerā€.
  • I applied the Master Rest and I haven’t noticed any change after the system reboot. The Navi section still showing the yellow triangle and the Navi fault message. Later I checked the GPS Antenna and It is connected properly into the APIM (and I don’t think the GPS antenna has issue, everything was just fine before the upgrade).
  • Can someone please help in this? Cheers!
Did you change the region information in the APIM asbuilt? That would cause this error.
Before the installation, I did check the region using Forscan in the APIM and the region was already set to EG (4547).
Are you in Egypt?
Did you set the navigation for NNG maps?
7D0-01-02 x*xx xxxx xxxx
USB2, Navigation (Telenav/NNG), Rear Electronic Feature Panel (REFP) (Rear EFP with Rotary Volume Knob)
0=USB2 Disabled, Navigation Disabled, Rear EFP Disabled
1=USB2 Disabled, Navigation Disabled, Rear EFP Enabled
2=USB2 Disabled, Navigation Enabled (Telenav Common HMI), Rear EFP Disabled
3=USB2 Disabled, Navigation Enabled (Telenav Common HMI), Rear EFP Enabled
4=USB2 Disabled, Navigation Enabled (NNG External HMI), Rear EFP Disabled
5=USB2 Disabled, Navigation Enabled (NNG External HMI), Rear EFP Enabled
6=Reserved
7=Reserved
If you have ā€˜2’ in the setting, then change to a ā€˜4’…
Hi F150chief. Yes, I am in Egypt.
No, I didn’t set the navigation for the NNG maps…
Yes, I have the (7D0-01-02 x*xx xxxx xxxx) set in 2. I’ll update it with 4 and let you know…
Perform a master reset after setting …the vehicle is outside? Do you have GPS lock? You might want to look at the ā€˜Location Diagnostics’ screen in the test settings menu. It will look similar to this…
Press FF> on the steering wheel and FF> on the panel at the same time for about 8 seconds. This will start the audio test, cancel that. Scroll down in the menu to location diagnostics.
I did the change to ā€œ4=USB2 Disabled, Navigation Enabled (NNG External HMI), Rear EFP Disabledā€ and the navigation seems to work properly. Thank you F150chief! Really appreciated!
A small notice, previously with the NA maps, the home screen was showing the 2D map on the left side of the screen. Now with the ROW, the map section replaced by the audio section and on the right corner appeared the black compass ā€œsimilar display as non navigation APIM unitā€ Is there a way to bring the 2D map on the home screen?
ROW does not display the navigation on the Home Screen.
Ok. Thanks again!
