Hello guys! Earlier this morning, I tried to update the maps only on my 2022 Ford Explorer XLT King Ranch, I set the initial settings on the Syn3 updater for the car configuration as:
3.4.22200, NA, Mexico,…, and Navigation = Yes
Then in the other window where the USB update flash is selected, I picked Middle East and North Africa in an attempt to add MENA maps, however after updating three times, the navigation map didn’t change and the map was still NA 21.
After this I decided to update the Sync as well (from 3.4.22200 to 3.4.23188), this time I changed both regions to MENA (car configuration and USB creation) because on the previous attempt I was given a prompt saying the USB might not work due to the difference in region while attempting to only update maps.
I plugged the USB into the car this time, and waited until it finished the first part of the update, then on the screen a message popped up telling me to recycle ignition so I restarted the car, while the screen itself went into restart, but from there it went completely black and hasn’t turned back on since, there’s no audio coming from the screen anymore, and even when checking for audio in the cluster menu it says “Audio is off” and for navigation the cluster menu freezes a bit then opens an empty list, the speakers are working fine I can hear the parking assist alarm and the turn signal sounds.
I checked with Forscan, the APIM module seems to be working and transmitting data as usual, the only fault code present was a loss of communication with the wireless charger, which is correct since it’s not working. Have I bricked my APIM or is there still a way to recover it since the module is working?
Old SYNC Version: 3.4.22200
Only the wireless charger.
Syn3 Updater Version: I just downloaded it from Cyanlabs this morning, so I’m assuming it’s the latest.
I will post it in the morning if necessary.
