SIGN_ERR01 when trying to update from Sync 3.0.17194
Hello everyone,
I have been trying for quite some time to update the SYNC 3 with EU navigation in my F-150 to the latest version. My original goal was to update to SYNC 3.4 using CyanLabs.
I prepared my SanDisk USB 3.0 64GB stick using the CyanLabs Sync 3 Updater 2.0 and then tried to perform the update. After inserting the USB stick, nothing happens for about 10 seconds. Then I get the error message SIGN_ERR01.
I then performed a Master Reset and tried the whole process again, but I still get the same error.
After that, I decided to try the official Ford update method instead. The version Ford provided for download was 3.0.23219. I downloaded the files from Ford using my VIN and prepared the USB stick accordingly. However, I get exactly the same error.
I also tried a different USB stick, a Sony USB 2.0 16GB, but unfortunately that didn’t work either.
When downloading the SYNC update files from Ford, I noticed that according to their records, version 2.3.17109 should be installed on my vehicle. However, the version actually installed on my system is 3.0.17194.
I also read out the APIM part numbers. They are as follows:
Assembly Part Number: JS7T-14G371-CDC
H/W Part Number: HS7T-14G380-BB
CCPU S/W Part Number: JR3T-14G381-AG
VMCU S/W Part Number: GB5T-14G374-CD
I also have access to FORScan if that is necessary or could help with diagnosing the issue.
Maybe this information will help identify what is causing the problem.
Any help or advice would be greatly appreciated.
Old SYNC Version: 3.0.17194
New SYNC Version: 3.0.23219
SIGN_ERR01
Sounds like a bad USB port or media hub.
When you do a Sync update you also want to make sure that nothing is plugged in the other USB port, not even a charging cable.
Since I regularly use both USB ports for Apple CarPlay and music playback from a USB stick, they are unlikely to be defective.
Before starting the update, I unplugged everything and made sure that the only device connected was the USB stick containing the update files.
That part number is a 32GB NA NAV APIM, EU NAV APIMS have 64Gb to support the larger map set and number of languages.
Thanks for the info. But how should I proceed from here? My navigation is currently working, and I have the European map set installed (EU 4 14). Since even the official Ford update doesn’t work, I’m not sure what the next step should be.
Share the log created when you created the USB with Syn3updater. But this looks like an issue with your APIM.
Version: 3.0.17194
Install Mode: Automatische Erkennung (reformat)
My20 Protection Enabled: Automatische Erkennung
APPS=NU5T-14G381-AE_1778770590000.TAR.GZ
MAP=1U5T-14G421-BAM_1748461682000.TAR.GZ
MAP=1U5T-14G421-BBM_1748459859000.TAR.GZ
MAP=1U5T-14G421-BCM_1748460093000.TAR.GZ
MAP=1U5T-14G421-BDM_1748460770000.TAR.GZ
MAP=1U5T-14G421-BEM_1748461035000.TAR.GZ
MAP=1U5T-14G421-BFM_1748461472000.TAR.GZ
MAP=1U5T-14G421-BGM_1748462187000.TAR.GZ
MAP=1U5T-14G421-BHM_1748462644000.TAR.GZ
MAP=1U5T-14G421-BJM_1748462970000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAM_1748464396000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBM_1748464677000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCM_1748464896000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDM_1748465073000.TAR.GZ
MAP_LICENSE=1U5T-14G424-BP_1748959609000.TAR.GZ
; CyanLabs Syn3Updater 2.14.2.0 Stable - reformat  Mode - Sync 3.4.26057 EU
FILES (20)
NU5T-14G381-AE_1778770590000.TAR.GZ (869.9MB)
1U5T-14G421-BAM_1748461682000.TAR.GZ (2.5GB)
1U5T-14G421-BBM_1748459859000.TAR.GZ (539.6MB)
1U5T-14G421-BCM_1748460093000.TAR.GZ (1.8GB)
1U5T-14G421-BDM_1748460770000.TAR.GZ (1.1GB)
1U5T-14G421-BEM_1748461035000.TAR.GZ (1.8GB)
1U5T-14G421-BFM_1748461472000.TAR.GZ (2.5GB)
1U5T-14G421-BGM_1748462187000.TAR.GZ (2.1GB)
1U5T-14G421-BHM_1748462644000.TAR.GZ (2.6GB)
1U5T-14G421-BJM_1748462970000.TAR.GZ (26MB)
4U5T-14G422-BAM_1748464396000.TAR.GZ (2.4GB)
4U5T-14G422-BBM_1748464677000.TAR.GZ (2.3GB)
4U5T-14G422-BCM_1748464896000.TAR.GZ (1.8GB)
4U5T-14G422-BDM_1748465073000.TAR.GZ (2.1GB)
1U5T-14G424-BP_1748959609000.TAR.GZ (1.7KB)
[26.09.2026 10:40:09] Selected Region: EU - Release: Sync 3.4.26057 - Map Version: F13 (2024) - EU (09 2025)
[26.09.2026 10:40:09] Install Mode: Automatische Erkennung (reformat) Forced: False
[26.09.2026 10:40:09] MY20 Protection: Automatische Erkennung
[26.09.2026 10:40:09] Formatting USB drive
[26.09.2026 10:40:09] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[26.09.2026 10:40:19] Checking Existing File: 1u5t-14g386-cb.tar.gz
[26.09.2026 10:40:19] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[26.09.2026 10:40:19] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[26.09.2026 10:40:19] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:19] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[26.09.2026 10:40:23] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:23] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[26.09.2026 10:40:24] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:24] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[26.09.2026 10:40:24] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:24] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[26.09.2026 10:40:26] Validated: NU5T-14G381-AE_1778770590000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:26] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[26.09.2026 10:40:32] Validated: 1U5T-14G421-BAM_1748461682000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:32] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[26.09.2026 10:40:33] Validated: 1U5T-14G421-BBM_1748459859000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:33] Checking Existing File: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[26.09.2026 10:40:37] Validated: 1U5T-14G421-BCM_1748460093000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:37] Checking Existing File: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[26.09.2026 10:40:40] Validated: 1U5T-14G421-BDM_1748460770000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:40] Checking Existing File: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[26.09.2026 10:40:44] Validated: 1U5T-14G421-BEM_1748461035000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:44] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[26.09.2026 10:40:50] Validated: 1U5T-14G421-BFM_1748461472000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:50] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[26.09.2026 10:40:55] Validated: 1U5T-14G421-BGM_1748462187000.TAR.GZ (Skipping Download)
[26.09.2026 10:40:55] Checking Existing File: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[26.09.2026 10:41:02] Validated: 1U5T-14G421-BHM_1748462644000.TAR.GZ (Skipping Download)
[26.09.2026 10:41:02] Checking Existing File: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[26.09.2026 10:41:02] Validated: 1U5T-14G421-BJM_1748462970000.TAR.GZ (Skipping Download)
[26.09.2026 10:41:02] Checking Existing File: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[26.09.2026 10:41:08] Validated: 4U5T-14G422-BAM_1748464396000.TAR.GZ (Skipping Download)
[26.09.2026 10:41:08] Checking Existing File: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[26.09.2026 10:41:13] Validated: 4U5T-14G422-BBM_1748464677000.TAR.GZ (Skipping Download)
[26.09.2026 10:41:13] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[26.09.2026 10:41:17] Validated: 4U5T-14G422-BCM_1748464896000.TAR.GZ (Skipping Download)
[26.09.2026 10:41:17] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[26.09.2026 10:41:23] Validated: 4U5T-14G422-BDM_1748465073000.TAR.GZ (Skipping Download)
[26.09.2026 10:41:23] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[26.09.2026 10:41:23] Validated: 1U5T-14G424-BP_1748959609000.TAR.GZ (Skipping Download)
[26.09.2026 10:41:23] Preparing USB drive
[26.09.2026 10:41:23] Checking Existing File: 1u5t-14g386-cb.tar.gz
[26.09.2026 10:41:23] Copying: 1u5t-14g386-cb.tar.gz
[26.09.2026 10:41:23] Validating: 1u5t-14g386-cb.tar.gz
[26.09.2026 10:41:23] Copied: 1u5t-14g386-cb.tar.gz
[26.09.2026 10:41:23] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[26.09.2026 10:41:23] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[26.09.2026 10:41:23] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[26.09.2026 10:41:23] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[26.09.2026 10:41:23] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[26.09.2026 10:41:23] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[26.09.2026 10:42:15] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[26.09.2026 10:42:18] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[26.09.2026 10:42:18] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[26.09.2026 10:42:18] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[26.09.2026 10:42:41] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[26.09.2026 10:42:42] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[26.09.2026 10:42:42] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[26.09.2026 10:42:42] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[26.09.2026 10:42:45] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[26.09.2026 10:42:45] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[26.09.2026 10:42:45] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[26.09.2026 10:42:45] Copying: NU5T-14G381-AE_1778770590000.TAR.GZ
[26.09.2026 10:43:34] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[26.09.2026 10:43:36] Copied: NU5T-14G381-AE_1778770590000.TAR.GZ
[26.09.2026 10:43:36] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[26.09.2026 10:43:36] Copying: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[26.09.2026 10:46:00] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[26.09.2026 10:46:06] Copied: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[26.09.2026 10:46:06] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[26.09.2026 10:46:06] Copying: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[26.09.2026 10:46:37] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[26.09.2026 10:46:39] Copied: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[26.09.2026 10:46:39] Checking Existing File: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[26.09.2026 10:46:39] Copying: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[26.09.2026 10:48:13] Validating: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[26.09.2026 10:48:17] Copied: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[26.09.2026 10:48:17] Checking Existing File: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[26.09.2026 10:48:17] Copying: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[26.09.2026 10:49:22] Validating: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[26.09.2026 10:49:25] Copied: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[26.09.2026 10:49:25] Checking Existing File: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[26.09.2026 10:49:25] Copying: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[26.09.2026 10:51:08] Validating: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[26.09.2026 10:51:12] Copied: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[26.09.2026 10:51:12] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[26.09.2026 10:51:12] Copying: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[26.09.2026 10:53:41] Validating: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[26.09.2026 10:53:47] Copied: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[26.09.2026 10:53:47] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[26.09.2026 10:53:47] Copying: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[26.09.2026 10:55:38] Validating: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[26.09.2026 10:55:43] Copied: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[26.09.2026 10:55:43] Checking Existing File: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[26.09.2026 10:55:43] Copying: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[26.09.2026 10:58:16] Validating: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[26.09.2026 10:58:22] Copied: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[26.09.2026 10:58:22] Checking Existing File: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[26.09.2026 10:58:22] Copying: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[26.09.2026 10:58:23] Validating: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[26.09.2026 10:58:23] Copied: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[26.09.2026 10:58:23] Checking Existing File: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[26.09.2026 10:58:23] Copying: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[26.09.2026 11:00:45] Validating: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[26.09.2026 11:00:51] Copied: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[26.09.2026 11:00:51] Checking Existing File: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[26.09.2026 11:00:51] Copying: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[26.09.2026 11:03:00] Validating: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[26.09.2026 11:03:05] Copied: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[26.09.2026 11:03:05] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[26.09.2026 11:03:05] Copying: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[26.09.2026 11:04:48] Validating: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[26.09.2026 11:04:52] Copied: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[26.09.2026 11:04:52] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[26.09.2026 11:04:52] Copying: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[26.09.2026 11:06:55] Validating: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[26.09.2026 11:07:00] Copied: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[26.09.2026 11:07:00] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[26.09.2026 11:07:00] Copying: 1U5T-14G424-BP_1748959609000.TAR.GZ
[26.09.2026 11:07:01] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[26.09.2026 11:07:01] Copied: 1U5T-14G424-BP_1748959609000.TAR.GZ
[26.09.2026 11:07:01] Generating reformat.lst
[26.09.2026 11:07:01] Generating autoinstall.lst
[26.09.2026 11:07:01] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Try with a different pendrive, but if that keeps failing there’s something wrong with the APIM or the software it’s using…
I have already tried a different USB stick. In the meantime, I also tried a custom installation with only the map data and language pack I need, based on the 32 GB storage limitation mentioned by Warlock.
One other thing that may be worth mentioning is that this F-150 is an import vehicle, since these trucks are not being sold at my region.
I have another question: this might be a long shot, but the APIM calibration right now is Calibration S/W Part Number: GB5T-14G375-CA.
In the APIM Firmware Production Releases post it was mentioned that configurations with xxxx-14G375-C*.vbf are for 8GB / 16GB ROW vehicles without NAV.
Could this be the reason for the problem? Could updating the firmware fix this?
If so, would the following be the correct configuration for my vehicle?
xxxx-14G375-F*.vbf — 32GB, ANY region with NAV (US Export vehicles) (Telenav)
Thanks for your help!
This sounds like hardware error or an “invalid” software running on the APIM.
If the new USB approach didn’t work, I do not think there’s something you can do to solve this issue.
