Hello, do you think its possible to add a single climate control menu on sync 3 screens to a 2015 ford f150 xlt
Do you have forscan and an adapter?
I would check this value to start → https://cyanlabs.net/asbuilt-db/sync3-apim/?search=Climate+Control+Repeater+Type
Not sure if that would activate it, but based on the title, it could.
Yes I do. I’ll confirm after making the change. Thanks
It’s not possible, SYNC 3.4 does not seem to have a Single Climate control ui
EDIT: well actually it does but only certain car types seem to support it.
You converted to Sync 3 if I remember, correct? Sync 2 would be different.
This relies on manual or automatic climate control. Manual climate control would be equivalent to single zone climate control on a 2015 F-150 XLT. Climate domain setting would be Climate Domain Off (Manual). For a retrofitted 2015 with manual climate control, you could try this, not guaranteed to work.
DE00/7D0-01-01: xxxx-*xxx-xxxx
0=Aux Audio Only, Rotary Volume, CGEA, North American Strategy
DE00/7D0-01-01: xxxx-xxx*-xxxx
6=DAB Disabled, Single Zone, Steering Wheel Angle Absolute, HD Radio Disabled, or
7=DAB Disabled, Single Zone, Steering Wheel Angle Absolute, HD Radio Enabled
(HD Radio or not.)
DE00/7D0-01-02: xxxx-x*xx-xxxx
6=MMI Disabled, CCT Manual, SSA Not Available, NRF Motorola Format
DE03/7D0-04-01: xxxx-xx**-xxxx
83=Climate Domain Off (Manual), Fan Repeater On, Temperature Repeater On, or
03=Disable Climate Control Repeater for Single Climate Control
Yes, me and my friend converted from sync 2 to 3. My F150 is Lariat so I have dual. My friend is xlt single climate control. My dual climate control in sync 3 works great. I’m going to try my friend xlt in the next few days and will reply with an update. Thanks
By the way cyanlabs is an awesome site
Hey, this is just a follow up to see how things went, since we haven’t had an update in the last week or so.
Would this be possible on mk8 fiesta currently on sync 3.0 ? If i upgraded to 3.4 i take it , it wouldnt on single climate ?
Single climate doens’t appear to work on Fiesta MK8’s i have one.
Hello, the APIM settings mentioned below didn’t work for the 2015 Ford F150 LT single climate. But it was a good try.
Thank You
I was thinking being a manual single control that it was not designed to, but thanks for trying. Well, at least we know…not guaranteed to work.
