Hi there!
I have an EcoSport, 2019, ANZ (South Am.), NON NAV.
Removed Gracenote and successfully upgraded from 3.0.18093 to 3.3.19052 (smaller NA voice file, no Gracenote).
Then upgraded to 3.4.19101, and then 3.4.21265.
Master Reset after each upgrade.
Now I’d like to install the PTB voice and, if possible, Gracenote.
Is there a way I could have a smaller voice file, just like you guys did with the “shrik” 5U5T-14G391-EM_1598637456000 one?
I’ve gone through the database searching for a smaller 5U5T-14G391-Bx, 5U5T-14G391-Dx or 5U5T-14G391-Fx, but the smallest one I found has over 1GB, gzip compressed.
I suspect the Nuance partition is too small (244GB), though. (please refer to the current as-built below).
Would it be the case for a downgrade/reformat back to 3.3, including a large ANZ voice file, so the partition increases?
VIN: (supressed)
Versão 5U5T-14G381-EU
Modelo APIM: JN1T-14G371-BBC
Tipo APIM: Non-Navigation
Tamanho APIM: 8GB
Espaço Livre APIM: 2.6G
15/03/2023 19:45:41 +00:00
Partition Type = Free / Total
/fs/Nuance/ = 940K / 244M
/fs/rwdata/ = 1015M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 132M / 1.4G
/fs/images/ = 2.6G / 3.0G
Installed Packages
5U5T-14G391-EM
APIM AsBuilt
DE00: 006A0006000008060880
DE01: 42520104C082018029800105
DE02: 0000010000
DE03: 000000E3070000
DE04: 1900190026AC
DE05: 40
DE06: 0E04330000000080E80000565667006B
Thanks in advance.
SYNC Region: ANZ
Old SYNC Version: 3.0.18093
New SYNC Version: 3.4.21265
MEM_ERR03 when installing the voice file separately.
Syn3 Updater Version: CYANLABS - SYN3 UPDATER - V2.11.8.0
[Please note that I keep other files on the memory key as they are from either previous attemps or successful upgrades. This expedites generating new tests. I assume it is not a problen given the "autoinstall.lst" file defines what will be used, therefore the other files will be ignored during execution.]
Operating System: Microsoft Windows 11 Home Single Language (2009)
Version: 3.4.19101
Region: ANZ
Install Mode: Deteção Automática (autoinstall)
My20 Protection Enabled: Desativado / Não MY20
Model: SanDisk' Cruzer Fit USB Device
; CyanLabs Syn3Updater 2.11.8.0 Stable - Autoinstall Mode - Sync 3.4.21265 ANZ
Item1 = VOICE - 5U5T-14G391-BP_1626959716000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G391-BP_1626959716000.TAR.GZ
FILES (13)
1u5t-14g386-cb.tar.gz (8,5MB)
4U5T-14G391-BJ_1552513817000.TAR.GZ (1,4GB)
GB5T-14G386-AA_56065.tar.gz (43,1KB)
Sync_WXBC3KRX_9BFZB55S1K8763454.xml (9,8KB)
GB5T-14G386-AB_134244.tar.gz (43,1KB)
5U5T-14G391-BS_1660772122000.TAR.GZ (1,4GB)
NU5T-14G381-AB_1665525837000.TAR.GZ (869,8MB)
5U5T-14G391-EM_1598637456000.TAR.GZ (188,6MB)
5U5T-14G381-AP_1555085337000.TAR.GZ (891,2MB)
5U5T-14G391-BP_1626959716000.TAR.GZ (1,4GB)
[15/03/2023 19:05:22] Selected Region: ANZ - Release: Sync 3.4.21265 - Map Version: APIM sem navegação
[15/03/2023 19:05:22] Install Mode: Deteção Automática (autoinstall) Forced: False
[15/03/2023 19:05:22] MY20 Protection: Desativado / Não MY20
[15/03/2023 19:05:22] Checking Existing File: 5U5T-14G391-BP_1626959716000.TAR.GZ
[15/03/2023 19:05:27] Validated: 5U5T-14G391-BP_1626959716000.TAR.GZ (Skipping Download)
[15/03/2023 19:05:27] Preparing USB drive
[15/03/2023 19:05:27] Checking Existing File: 5U5T-14G391-BP_1626959716000.TAR.GZ
[15/03/2023 19:06:26] 5U5T-14G391-BP_1626959716000.TAR.GZ exists and validated successfully, skipping copy
[15/03/2023 19:06:26] Generating Autoinstall.lst
[15/03/2023 19:06:26] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
