Sound Settings not sticking Sync 3
As some of you might remember I purchased a Used Ford Fusion APIM for my Ford Edge. I went thru all the APIM setting and compared them to my Original APIM, using Forscan. But i seem to have an issue with the Sound settings. When I try to change the Fade or even the Bass, matter of fact of those settings… It sticks for a couple seconds but then snaps back to the original settings.
Any advice on what settings I need to change on the APIM using Forscan would be greatly appreciated. I am sure it is something silly
Install Type: OEM Replacement
Old SYNC Version: 2.2.16280
updater worked perfect
Maybe post your AB settings for your APIM here? Otherwise were just guessing as what they might be. Might not hurt to even post your ACM AB settings also.
Almost sounds like a “Sony” mismatch.
You have the Sony sound system and the APIM config is set as not having it or vice versa.
Fast, easy way to check to see what APIM has in config, go into audio settings and see if you have an option of choosing Surround vs Stereo. If those are present it usually means the config is set for the Sony audio.
